who has over 120000 miles on their auto max
wondering how many people have 120000 miles or over on their automatic maxima - are you guys still modding your car or do u feel its just a waste? currently i have 130000
161k and counting. I've replaced cv boots, starter, KS, radiator, camshaft and crank sensors, right and left O2 sensors, lowered with MAxspeed springs with AGX, y-pipe, and K&N cone filter. Runs hella hard and smooth.
155k planning to get a y-pipe soon.
Problem History - Starter, CV Boots, 02 Sensor, Evap Control Volume, Knock Sensor, Radiator blew (i rear ended someone), and A/C Compressor. I'm thinking there's more but never got em checked out.
I've got 155000miles on mine and the only thing to need repairing was the starter motor in November, everything else is original
I do plan on doing some modding later on, hopefully later this year if things turn out well
220,000 miles starter replaced (lifetime autozone), tokico blues (feels slightly better than stock), and replaced the cv joints, have 2000 stock rims on my 1995 gle with all the packages except fog lights and no leather. Converted front badging to a 1997, it's very easy but still have a gap at the bottom.
Future mods will be y-pipe, hacked intake, and maybe a carbon fiber hood if I can find one cheap.
Still hate the color of my car, maroon...would rather dark blue, white, silver, or grey.
Only problem I am having now is programming the keyless entry.
132k
Starter was squealing when it was cold... Took it apart, then cleaned and regreased it with synthetic Mobil 1 grease. (around 2 years ago)
Purge valve had problems. Took it apart, cleaned and lubed it. No problem. (around 2 years ago)
Oxygen sensor threw a code. Took it off, sprayed it down as well as I could with carb cleaner... Reinstalled it, and it works fine. (around 2 years ago)
Heater resistor went out. (only speed that worked was high) Replaced about 6 months ago.
Right front wheel bearing and hub started making a horrible racket. The bearing started spinning on the hub. I replaced it about 4 months ago. No more problems.
I've gone through two sets of hood props. The second set was replaced under warranty.
That's everything.
That's everything.
120,300 on a 96gle
replaced starter, alternator, knock sensor, coolant temp sensor, 2 o2 sensors and brakes (pads, rotors, calipars) within last 10k miles
needs struts right now
all on original tranny too
Armelius, Oil changes aren't mods but its good that your keeping up to date with maintenance. Without maintenance modding is pointless.
162,000miles. New struts and shocks and one coil pack. Another is going bad, plus there is a huge hole in my mufflers. Everthing else is original. Runs like a dream.
No mods, no time or money for them. (Married with kids sucks, at times).
Originally Posted by broaner22
You can't have a GLE without leather or with foglights. You might wanna check the VIN buddy cause my sources say you have a GXE. So go back to whoever you bought it from and get your money back.
To the other person who asked the Tokico blues are just like stock only slightly better. No not lowered, not really interested in the lowered look. Sometimes I load up my car and a lowered car won't handle the weight.
Forgot I replaced rotor and brake caliper.
187200 Kilometres (116064 miles) on mine....so, approaching 120k.
Problem/Repair History: CV-Joints, Starter, Stabilizer links, Replaced 1 Coil, Replaced 1 Injector, Brakes and Rotors, Shift Lock Solenoid, Drivers side window motor.
Current unresolved issues: Air Bag Computer, Bad thermostat, Cylinder 5 misfire.
....and I baby her. Really, I do.
No mods. I'm too poor from all the other repairs...;-)
For me, personally, mods are a waste of time. But that is a matter of preference, budget, etc. With a little money and TLC, any Maxima can be worth the time and money to fix up real nice'n prettylike.
135,000 on my 95. Its on its 3rd transmission though. First just blew up, 2nd just died on my with a busted tourqe conv. hopefully this 3rd on is the charm. Think about 3 or 4 axles have been replaced. KS, 2 front O2 sensors, all rotors, rear brake calipers, cranks shaft pulley, and belt tensioner.
130K+ on my ride (210K Kms).
still modding...next up:
A32 headlights to install
DVD deck to install
"Dynamat" car
LED tails/turns
I've replaced a bunch of stuff...most recently, rotors/pads/lines
check website for list of mods
AND I'm still on my original tranny!
FLO_BOY
DVD deck to install
"Dynamat" car
LED tails/turns
FLO_BOY
