Q: after installing knock sensor
Old Feb 27, 2004 | 09:50 PM
Allen's Avatar
If I install it today, how long until I start to feel the difference? I've heard people say instantly, and some have said you have to drive it a couple hundred miles before the ECU adjusts. Which is true? Also, if the ECU has to adjust then is there a way to just manually reset it or force it to adjust instantly? thanks!
Old Feb 27, 2004 | 10:15 PM
lxl - MaX's Avatar
bump... i have same question
Old Feb 27, 2004 | 10:26 PM
vipervadim's Avatar
I like Maximas
yeah make sure to clear the CEL if you do have the 0304 code and then reset the ecu. start your car and give it plenty of gas so the ecu can start adjusting itself. you should feel the full power of your car after 2 days and roughtly 30 miles
Old Feb 28, 2004 | 05:29 PM
Allen's Avatar
how do you clear the CEL? how do you reset the ECU?
Old Feb 28, 2004 | 05:34 PM
collin's Avatar
RESETTING THE CHECK ENGINE LIGHT
To reset the engine light is a simple procedure.
1. Turn the selector screw clockwise to its stop.
2. Wait 2 seconds.
3. Return back by turning the screw counterclockwise to its stop.
4. IMMEDIATELY REPEAT steps 1 to 3.
http://vbxmaxima.8m.com/ecu.html
Old Feb 28, 2004 | 07:15 PM
Allen's Avatar
cool, does that also reset the ECU or is that a seperate procedure?
Old Feb 28, 2004 | 07:34 PM
nismology's Avatar
From what I've read, that actually resets the ECU. You would need a special instrument to clear the CEL without resetting the ECU...
kjlouis
Nov 24, 2018 06:09 AM
rbuswell
Nov 12, 2016 04:11 PM
maxinout93
Oct 27, 2015 01:29 PM
Slamrod
Sep 3, 2015 07:38 PM
maxinout93
Aug 20, 2015 02:17 AM
