Haft Shaft Removal
Old Mar 6, 2004 | 05:25 PM
imaflip's Avatar
Haft Shaft Removal
I need instructions on how to remove the driver's side haft shaft on a 95 with 5 spd no ABS or FSD. I got the passenger side replaced but I couldn't pull out the driver's side. Is there a circ clip that holds this in? If there is, how do I get to it?
Old Mar 6, 2004 | 05:41 PM
njmaxseltd's Avatar
Pry, pull, sweat, work harder - It'll come out, there's no tricks.
Old Mar 6, 2004 | 06:11 PM
shnoog's Avatar
I just replace my drivers side yesterday. once you get everything else removed just grab ahold of the alxe and start pulling, A prybar is very beneficial or a slide hammer is a great help.
Old Mar 7, 2004 | 08:54 PM
imaflip's Avatar
Thanks guys, I'll give it a try again tomorrow evening. In the mean time maybe someone else has another suggestion, I'm open to the easiest way possible.
Old Mar 9, 2004 | 10:23 AM
imaflip's Avatar
Finally got the haft shaft replaced. It did take just a bit of pulling and it popped right out. Many thanks to njmaxeltd and shnoog, both of my haft shafts are now in new condition.
Old Mar 9, 2004 | 02:04 PM
Mishmosh's Avatar
By chance did you replace the axle seals? I am having extreme difficulty putting the driver's axle seal in flush. Any tips?
Old Mar 9, 2004 | 03:44 PM
imaflip's Avatar
Sorry, didn't do that since I didn't see any leaks around the area before disassembly. With experience from other vehicles, the best way to put in seals is to use a seal driver tool that way there's little chance of ruining them. They're cheap at Harbor Freight.
my03maxima
Jul 28, 2024 07:40 AM
doctorpullit
Mar 29, 2016 11:08 AM
RealityCheck
Oct 2, 2015 06:34 PM
jaydot901
Sep 29, 2015 01:18 PM
