Rear brake info requested...
I will be doing the rears tomorrow and am looking for two things:
a) brake bolt torque specs
b) brake pad bedding procedure
Also, any other hints/gotchas are welcome.
<edit>I should say it's a '99 SE</e>
Originally Posted by WhiteMax96
Caliper mounting bolt (front and rear): 16-23 ft-lbs.
First welcome to the org!
Second, if it's the first time you change your brakes, i suggest you to buy the Haynes manual for your Maxima. It's a real most.
I've done the front ones which were very easy. I let the dealer do the rears the first time...which was a huge mistake.
My only major question was how Nissan implemented the emergency brake. Other than that...rear brakes are rear brakes. I'll find out how they do in about 1 hour.
Huttig2009
Sep 25, 2015 03:31 PM
RealityCheck
Aug 5, 2015 06:18 AM
