Camber kits.
So easy
Alright to start off with Eibach makes a really durable camber kit for our cars. It is actually just a bolt that replaces the upper of the two bolts on the strut mount. It is very easy to put in, you just have to first loosen the bottom bolt and then remove the top bolt, this is the bold you will be replacing with the camber bolt. Put the new bolt in with it lined up how you would like the camber, negative or positive. They are very simple and worth the couple of dollars. Here is where I got mine from...
http://www.autocarparts.com/part/930/2
Good luck
Good luck
Apr 16, 2020 05:15 AM
Pied
Sep 26, 2015 03:29 PM
