Problems changing rear brakes.. help!`
Old Mar 20, 2004 | 11:25 AM
Oblongshapes's Avatar
I have the caliper off, but i cant depress the piston in the caliper to slip over the new width of the brake pads. It wont go in any farther with a C-clamp... im wondering.. do I have to remove the brake hose to release pressure to push the piston back. that seems like it doesnt makes sense... any hints or suggestions?
Old Mar 20, 2004 | 11:31 AM
UncleMax98's Avatar
Turn the piston clock-wise to push it back into the caliper housing. You can use needle-nose pliers or buy a tool from auto part stores ($10).
Make sure to line up the cut on the piston face to the nub on the back of the brake pad so the pad can sit flush to the piston.
Old Mar 20, 2004 | 12:15 PM
thanks man
Old Mar 20, 2004 | 12:56 PM
Prophecy1's Avatar
Yahp.. Use a Pair of needle nose pliars. Check chiltons for more info.
Proph
Huttig2009
Sep 25, 2015 03:31 PM
homeyclaus
Sep 3, 2015 06:15 PM
laparka66
Aug 6, 2015 09:36 AM
RealityCheck
Aug 5, 2015 06:18 AM
