How To Remove 4th Gen Door Panels - Quick Guide
Old Mar 21, 2004 | 10:12 PM
Chickan's Avatar
How to remove your door panels - A quick reference
I searched around for a bit today, and was unable to locate a guide detailing how to remove 4th gen door panels (most likely similar for other years). This is useful when installing new speakers, fixing window switches, installing car alarms, etc.
This was done on my 95 GXE (5speed Cali if you really want to know) on 3/21/04 while it was snowing outside (Ohio weather is crazy).
First off, locate small tray pictured here:
Pop off that screw cover, then take the screw out.
You can take out the whole tray if you need to (useful for keeping track of screws), though not nessesary.
Next locate the two screws on the bottom of the door panel pictured here:
Take both of those off as well.
Locate your door light, pictured here:
There is a small conector that attaches to it, and I popped off the plastic cover (take a small flat head to either left or right side of it), and removed the two screws holding it in place. This allowed me to pull it out, giving easy access to the attached connector. Alternatively, you can probably reach your hand under the door after you have completed the next step.
Next, apply pressure all along the door panel, start at the bottom, then do the sides. There are several pop-screws that will pop out with a bit of force. Also, having the window down helps a bit with removing the whole door panel.
The last thing to remove is the doorlock/window switch connector, which can be a little stubborn, be gentle so as to not break it.
Removing this black piece may also be of some use in particular projects, it easiy pops out with a flathead, shown here:
To reinstall, just reverse the steps. Pop the black panel back in place (if you removed it). Reattach both connectors. Align the door panel on the window lip, then pop the tabs back into place. Attach the bottom two screws, then attact the center screw & tray, replace screw cover, and you are done!
Old Mar 22, 2004 | 05:13 AM
Ceasars Chariot's Avatar
Old Maxima Legend
good job !
Old Mar 22, 2004 | 05:40 AM
endus's Avatar
An atavistic endeavor...
Nice, but I think you forgot the hardest part...taking the door handle cups out. Can you get the door panel off without taking them out?
Old Mar 22, 2004 | 05:56 AM
clee130's Avatar
Ummmm ... https://maxima.org/shoptalk/sub_modi...t2/index.shtml
Old May 2, 2005 | 10:48 PM
meegosh's Avatar
pics aren't broken... well sorta, they're still there, just right click and goto properties and go right to pic... they just don't allow linking from other sites.. awesome tutorial thanks a million!
Old May 3, 2005 | 10:34 AM
BLaKtOut's Avatar
anyone know where to pic up the I30 door handles ive been looking on ebay and can only find the J30 seller says they will fit on maxima no problem but iwant the I30 any suggestions
Old May 3, 2005 | 12:12 PM
Old Maxima Legend
edit: webpage is changed will just toss this photo up for this thread to add more info, basically every arrow points to what needs to be taken out.
1. pop out, use a cloth and flathead screw driver, do it enough and you will find the sweet spot that pops it out easier.
2. pop out electric window thingy, same thing cloth and flathead screw driver, will need to disconnect motor from wiring harness.
3. flat head screw driver will pop out the tab , use phillips head to take out screw
4. (2) phillips head screws here,
5. pop out the around the edges of the door panel and then life the door panel up and off.
Old May 3, 2005 | 12:38 PM
9maxima5's Avatar
Ceasar great page. Very helpful
Old Nov 29, 2006 | 01:41 PM
Maxima Dionysis's Avatar
<-- Noob. I've got a tall order. Recently an uninsured motorist hit me on my drivers side seriously damaging my front and rear exterior side panels. I bought this car just weeks ago and my insurance hasn't come through yet, so I'm on my own in bringing her back to her beautiful self. Does anyone know somebody who could hook me up with a guide to removing the panels, possibly taking off the door, and banging out as much of this damage as possible? I'd start a thread, (not in here) but I don't have enough posts yet.
Any help would be much appreciated.
Old Feb 27, 2007 | 06:23 PM
bmr12's Avatar
Some helpful hints for those who, like me, may try to do things in a different order or struggle to get it off. I did 4, 5, and then 3 of Caesar's post above. Then I removed and unscrewed the courtesy light in the door, a necessary step to get enough room to maneuver.
At that point, I could then lay on the ground and peer up and see how to get the door release thingy to pop out. It was much easier and less prone to damage to release it from the inside of the door.
Since I was doing the driver's side door, I also had the trunk popper button in the arm rest to deal with. I skipped #2 and instead just removed the wiring harnass from the back side of the trunk popper button. It was possible to leave the window controls connected and move the panel out of the way for what I needed to get at, but it could also be disconnected if necessary.
Old Mar 1, 2007 | 12:38 AM
Dan_E_Boi84's Avatar
Door panels are simple just be carefull about the door handle trim because you can easily dent the panel...I did...DAMNIT
Old Mar 29, 2009 | 10:04 AM
trooplewis's Avatar
The "pop out" door handle cup does not pop out very easily, and if you force it you will break it in half.
Pry it gently forward and you will see the top clip point, toward the front of the car. Gently pry up on the clip with a small flat-tipped screwdriver while prying the cup away from the door with a wide-blade flat tip screwdriver, and it will come out nicely.
After I broke the first one and saw what was going on, the 2nd door was easy. 8-(
New Infinity Reference speakers sound a lot better than the stock non-bose paper cone speakers.
Old Mar 29, 2009 | 11:22 AM
EEMaxima's Avatar
Good info! Both of my back windows need help. The drivers side motor runs but the window only shifts slightly and the passenger side has no power at all (lock or window).
Old Mar 29, 2009 | 11:42 AM
pmohr's Avatar
No more Maximas...
Ever A32 I've ever removed the door panel, the handle pulled right out
And 2 year old thread FTL.
Old Mar 29, 2009 | 03:13 PM
Coolsaber57's Avatar
old thread, but he's right, those MFing handles are really hard to get out, and you have to give just the right amount of force, otherwise you'll break it.
Old Mar 29, 2009 | 06:25 PM
nitromax's Avatar
yeah, old thread, but i've always popped the lil' cover over the screw in the bottom of the door pull/cup, removed the screw and just lifted the cup out of the door (#3 above). the window switch holder, i leave in place and just unplug it once the panel is off. no need to fight with pulling it out of the panel unless replacing that part. biggest fight is bezel around door handle...still it's only a few seconds to remove. with the panel off you can push the switch hoder out from below easier by pressing the clips to release.
just my.02
Old Mar 29, 2009 | 08:45 PM
trooplewis's Avatar
Jeez pmohr, it's not like I resurrected an old thread, it's a STICKY and it never moves. I read it thoroughly before I removed the panel and NO ONE mentioned anything specific about the door-handle cup, other than "pop it out".
Well I can testify that if you just stick a screwdriver behind it and pry, you will break off the bezel if you do not unclip it first, depending on where the screwdriver makes contact with the cup.
But it's easy if you look for the clip on the door panel and pry it up a bit. BTW, there's a clip on the top and one on the bottom, but you only have to unclip one and it slides right out.
Nitromax, you are talking about the cup in the armrest. I am talking about the trim plate behind the actual door handle/lock, yes, the bezel you called it.
One other thing, I did not have to remove any of the P/W switches before removing the panel. You can unclip the connections on the back of the panel after you remove it from the door, and leave all the switches in place. That works for the trunk release, the drivers P/W switches, and the passenger P/W switch.
Old Mar 29, 2009 | 08:48 PM
pmohr's Avatar
No more Maximas...
It's not a sticky, it's in the stickies. Bit of a difference.
FWIW you did resurrect an old thread, the post before yours was in '07. And calm down, it's not like I raged on you for bumping it.
Indeed, if you go shoving screwdrivers everywhere, you're going to start breaking stuff, especially small trim pieces. Personally I don't even use tools, I just pull it off, and they always come right off for me.
Old Mar 29, 2009 | 09:26 PM
trooplewis's Avatar
OK, I see that I did indeed bring it back to life...sorry bout that.
Old Mar 29, 2009 | 09:28 PM
pmohr's Avatar
No more Maximas...
No biggie, this thread is decent and you did add some good information.
Actually, now that I think about it I've never seen this thread before, heh.
Old Mar 29, 2009 | 09:30 PM
oddball86's Avatar
I hated getting those stupid handle trims out. Never got easier. That was literally the hardest part of mounting my crossovers to my door panels... Everything else was a breeze :-(.
Old Mar 30, 2009 | 07:48 PM
IlyaK's Avatar
The Golden One
Why does the dude who made the thread 5 years ago remove the black mirror piece? Not necessary. Neither is the light piece, just unclip the connector. To plug it back in, use needle nose pliers.
Old Mar 31, 2009 | 02:34 PM
Nozama's Avatar
Grumpy old guy
The right tool for the job makes things nice as well.
http://www.sjdiscounttools.com/lis35400.html
Using this means the plastic clips and the spots they lock into never break.
Of course I've done alot of interiors so it may not be required for the one off interior job.
Old Apr 1, 2009 | 06:50 AM
Looks like it would work, but it's just another Fing tool to buy
Old Apr 2, 2009 | 06:20 AM
captainjohn's Avatar
I just replaced my door speakers yesterday, and had a couple of things to add to this.
1) The door handle cup- really a PITA. Push the cup towards the front of the car, and pull out the back side. Now, you have 1 of 3 clips released. The next two oppose one another about 80% of the way towards the front of the cup, 1/4 inch back from the face of the cup on both the top and bottom. I used a small screwdriver and pried the black clip up to release the top. Once the top is released it comes right out.
2) I didn't need to remove the door light to change the speakers. Found out by forgetting to remove it...
3) GET THAT PANEL TOOL! With both doors I found that the lower two clips come out, but the upper two, broke right off, and stayed in the door (not the panel). I didn't think much of it initially, but now noise is coming through the top of the door panel where it's not held tightly to the glass anymore... :-(
At least I planned to go back and soundproof it.
Old Mar 6, 2010 | 03:44 PM
illmortal's Avatar
I need to put my rear passenger Window back on the tracks (since some how it fell off the tracks.) I'd like to know if these are all the screws I need to remove for an I30, I assume I do but I don't want to take it apart without instructions, don't need to break anything.
And the prying tool mentioned above, that's easily found at an autozone, right?
Old Mar 7, 2010 | 06:48 PM
VQuick's Avatar
Chassis Freak
The rear door is a little different but it's the same idea. You really don't need a prying tool. I used a screwdriver wrapped in a thin cloth, but of course any strong thin plastic tool is best to reduce the risk of scratching anything. Once you get the screws off you just pull the panel straight off. If you spend a little time searching the forum I'm sure you can find a detailed write-up.
Here is my rear door with the panel off if it helps at all.
Old Mar 8, 2010 | 05:14 AM
illmortal's Avatar
Thanks a lot bro! Gonna attempt to fix my window today.
Old Mar 8, 2010 | 06:26 AM
Eyce's Avatar
Kind of on topic..
Does anyone have any tips on how to prevent the door speakers from rattling? Other than like..Dynomat.
Old Mar 8, 2010 | 10:43 AM
Webhead's Avatar
the suicide doors make be a good like for me
Old Mar 8, 2010 | 04:50 PM
illmortal's Avatar
I've only found 1 screw... which was where the armrest is. There's no screws on the bottom of the door and I'm having a hard time prying the door handle off... I have the back of it loose (where the lock is) but it's not budging in the front.. and I'm scared to snap that piece in half.
EDIT: Finally got the handle off.. just needed to add more force.
Just found out that the pulley broke which is what's not letting the window get pulled up. I don't even think I'll be able to find a window pulley via internet/dealership.
Old Mar 8, 2010 | 06:05 PM
balkan's Avatar
Same thing happened to me. I found a regulator+motor off of a 99 at a junk yard for $15.
You can find them on eBay for ~$30-$40, IIRC. Try contacting the seller and seeing if they'll sell it without the motor (regulator only). Might get it cheaper that way.
Old Mar 8, 2010 | 11:06 PM
illmortal's Avatar
Thanks a lot for your input bro. Ill check it out on ebay. I kept wondering why I would hear a loud click/pop sound as soon as I would try to raise the window. Now I know.
Thanks again!
Old May 29, 2010 | 06:07 PM
AJcole123's Avatar
This helped alot im trying to install 2 new door speakers (infinity) that were in my old car and i couldn't figure out how i could get at the speaker. I guess i have to take the whole door off. Kinda rediculous. But thanks for the pictures they help a whole lot
Old May 30, 2010 | 07:27 AM
Nozama's Avatar
Grumpy old guy
There is no such thing as too many "Fing tools"..
I actually enjoy when people use my tools and see how easy things can be if you have the right tool, they usually decide to buy the tool after that.
Work smart and it will appear you are working hard even when you're not.
Old May 30, 2010 | 01:15 PM
j-dawg's Avatar
I bought a set of plastic prying and clip-removal tools on clearance at Harbor Freight for $2. Totally worth it - it saves you a ton of time and frustration in dealing with those little plastic clips and you don't have to worry about breaking them. I like that mine are plastic because I don't have to worry about damaging the interior or scraping the paint, though they do flex a little more than I'd like. If you're overhauling your interior or even just trying to track down rattles like I am, it is worth the $2 or even the $7 to buy.
Old Oct 27, 2010 | 06:44 PM
GeoKohler's Avatar
I have some chrome door handles off my I30 97 parts car. I'm not sure if I'm going to use them on my restoration. If not you can have all 4 for $40 plus shipping.
Geo
Old Oct 27, 2010 | 07:56 PM
tigersharkdude's Avatar
look at the date noob. Did you seriously just bump a thread from 2004 to try and sell your chrome door handles
Old Oct 27, 2010 | 08:46 PM
Swazey's Avatar
yea and be careful cuz that plastic is soft and its easy to tear up
Old Feb 26, 2011 | 01:46 PM
NickStam's Avatar
I want to add my experience if it helps, because I referred to this thread before installing my speakers:
1. Taking the door apart was for the most part a piece of cake until you try and get that housing off around the door handle. Crutchfield instructions say just to pry it off, but that doesn't really work. Popping off the side closer to the front of the car works, but that didn't release the entire door for me. Releasing it up inside the door worked, but what a PITA. Here's a pic while I'm laying on the ground directly beneath the door while it's separated trying to release that tab. Once you pop that, everything comes off. Not sure how you can do it any other way. FU Nissan!
2. A small mistake I made was not yank up on the door before trying to remove it. That results in some of the screw/tab things to get stuck in the metal part of the door instead of staying with the cover. In my pic, the blue tab stayed because a pryed it off with the tool prior to lifting. I got frustrated and just yanked, and the cream tab stayed in the door.
3. If you leave it stuck in the door it won't create a nice seal when you put everything back together. It should look like this before you pop the piece back on.
4. Get one of these, it makes life easier. I had it already from removing interior in the trunk to get at tail lights.
