Adjustable Air/Fuel
Old Mar 24, 2004 | 11:19 AM
PoePoe2797's Avatar
Adjustable Air/Fuel
I want to be able to somewhat override the ecu air/fuel mixture ratio with the flip of a switch and the use of a potetiometer. The mixture is set by the ****, but I have a few questions. I heard of this being done to the water temp sensor with best results, but does anyone know the exact wires and such to tap into? Thanks
Old Mar 24, 2004 | 11:21 AM
Jeff92se's Avatar
I'm needing a caw
And this will accomplish what?
Old Mar 24, 2004 | 11:23 AM
PoePoe2797's Avatar
Fine tuning for a turbo project ....not my car though
Old Mar 24, 2004 | 11:30 AM
PoePoe2797's Avatar
I know there is products like that but they cost a lot of money and do the same thing that a potentiometer would do for only like $5 and a little bit of custom work
Old Mar 24, 2004 | 11:52 AM
Stephen Max's Avatar
A potentiometer is not going to allow you to make adjustments based on rpm, like the SAFC will.
Old Mar 24, 2004 | 11:58 AM
Jeff92se's Avatar
I'm needing a caw
Also, a pot will only send 1 ohm signal per setting. Unless you constantly have your hand on the **** adjusting the signal maybe 10x per second(provided you know what your a/f is in real time), I seriously doubt you can do anything close to what the oem 02 can do. Provided you don't run into a tree
tarun900
19
Dec 20, 2021 06:57 PM
aw11power
Oct 10, 2021 04:57 AM
Apr 16, 2020 05:15 AM
leatherneck
Sep 30, 2015 09:16 PM
