CAI install-O2 sensor help
Old Apr 1, 2004 | 06:56 PM
AusFlt's Avatar
On the stock air box('96) there is an O2 sensor just infront of the MAF. On the CAI there is nowhere for this to go, so I am left with an open plug that used to plug into it. My question is....Does this affect anything with the engine to leave it off? Or should I somehow rig the CAI to include this sensor. None of the install helps I could find had anything to say about this sensor.
Help is appreciated.....Aus
Old Apr 1, 2004 | 09:16 PM
Tyrexx's Avatar
bump,
i dont think theres a o2 sensor just in front of the MAF
Old Apr 1, 2004 | 09:43 PM
LastBoyScout's Avatar
no o2 sensor...just a temp sensor
you can do what you want....i plan on installing it when i get my cai.....
if you do so, be sure to measure twice and cut once.
Old Apr 1, 2004 | 10:13 PM
MrDicks95SE's Avatar
Offset Is Everything.
just hang it anywhere or tape it down. do as you will to it. just dont cut it off.
Old Apr 3, 2004 | 11:17 AM
AusFlt's Avatar
OK, This is what I did....
When I installed the CAI I noticed on the small pipe that there was a rubber seal with a plastic stopper in it. I though, "I bet the temp sensor will fit in there". Well after pulling the CAI apart and taking that pipe off the car I found that it did fit, bit snug but it fit. I had to cut the rubber a bit on the inside so that there will be good airflow thru the sensor, but I think it is a great solution. No screws or nothing. It should hold all by itself. But I didnt want to trust it so I just Zip tied it around the pipe, just to make sure it doesnt fall out.
Good easy solution overall. Considering I had some JB weld and was all set to cut some holes in the pipe and Rig up a bracket for the stupid sensor.
Thanks for the help...
AUS
Old Apr 3, 2004 | 01:33 PM
Tyrexx's Avatar
ausfit, where are you going to inject you nitrous now??????
Old Apr 3, 2004 | 02:26 PM
AusFlt's Avatar
Didnt think about that.....I guess just strait into the cylinders..hehe
Nah, dont think I will do nitrous ever on this car anyway
my03maxima
Jul 28, 2024 07:40 AM
Kyle Lee Cleveland
Sep 28, 2015 09:01 PM
Sep 27, 2015 08:37 AM
