Y-pipe=HELL
Old Apr 2, 2004 | 04:21 AM
Kta920's Avatar
Y-pipe=HELL
Whoever said puttin the wsp y-pipe on yourself was WRONG.I estimated last night it would take about 4 hours,so I planned to start at 6 and finish around 10.Got workin...the six bolts that connect to the headers were a pain in the *** to get off,but I worked at 'em and got 'em off.Then...I moved down to the cat.The bolts around the cat are almost welded onto the nuts and cat.I tried PB blaster and cuttin the bolts,but theres no bolts to cut! So that took til about 11:00 and I stopped.So now my car is sitting up on a lift in my garage until I can get back to it this weekend.Not too happy.I hate the New England weather that made my car rust out.Guys in NE doing the y-pip yourself,good luck!
p.s.-You guys have any suggestions on getting them off??
Old Apr 2, 2004 | 05:01 AM
MaxedOutOfCash's Avatar
Pizda Boy
i'm in jersey....we wd-40'd the hell out of it...let it sit & we used power tools to get them off....but they are a bish to take off though...
Sam
Old Apr 2, 2004 | 05:09 AM
Kta920's Avatar
wd-40ed what? all mine is is a little nub.its so rusted it's almost a perfect circle,no notches or anything to put power tools on! I was thinking about torching em,but I didnt wanna mess up and ruin something.
Old Apr 2, 2004 | 05:10 AM
Oblongshapes's Avatar
Yea... I live in Pittsburgh and i couldnt get it, or at least i didnt feel like doing all the work involved. I just payed some dude a meinike to do it under the table for 70
Old Apr 2, 2004 | 05:12 AM
njmaxseltd's Avatar
Heat is your friend.
Old Apr 2, 2004 | 05:13 AM
icefishing's Avatar
Got a blow-torch?
Old Apr 2, 2004 | 05:15 AM
Kta920's Avatar
What if I dropped the whole exhaust and just f-in burn 'em off (sorry,little frustrated my max is sitting in my garage useless)?? That'd work right...precautions? Dont wanna burn the cat.
Old Apr 2, 2004 | 05:25 AM
Tort's Avatar
Mine were very rusted as well, but I just replaced my whole exhaust at the same time, took me about 3 hours to do the whole exhaust from the y-pipe back.
Old Apr 2, 2004 | 05:57 AM
icefishing's Avatar
Whatever it takes. Got a saws-all? or somthing els that will cut metal?
Dont F*** it up so bad to were you cant put the y-pipe on after you get it off.
Taking the hole system off would be alot easier to work with(stick it in some kind of vice) it seems pritty drastic but if you have already spent that much time with the darn thing why not man got for it and give it hell
good luck
Old Apr 2, 2004 | 06:01 AM
Guinader's Avatar
I knew I was going to run on the same problem you have, so Before I had to remove my Y-pipe I took to a mechanic, and asked him to put new bolts on my cat. (he torched my old ones for $15).
But then as the worst luck of all, the "bolt of Hell" did not wanted to come out on my y-pipe.
comclusion: I drove my car with the y-pipe hanging by 2 bolts down to a mechanic. he took the pipe off and charged me $25
here is a link to my tread: it doesn't help much but you can always read.
http://forums.maxima.org/showthread.php?t=298373
Old Apr 2, 2004 | 07:50 AM
Nealoc187's Avatar
SLOW
All you have to do is take it to a muffler shop and they will cut what is left of the old bolts off with a cutting torch for like $20.
Old Apr 2, 2004 | 07:56 AM
mansurxk's Avatar
torch them, i wouldve done it myself but i dont have a lift so i took it to the local mechanic and he did it for $30, you need a hammer and bang out the bolt once its cherry red, im not sure propane would work, but i had the EXACT problem, there was no bolt left, dont waste your time trying to drill and cut or wahtever else you can think of, just torch it, what if you put a metal plate in front of the cat to protect it, the guys at midas dindt want to torch it cuz they feared they'd burn the cat, fact is, it didnt burn just put some sort of shield in front of it if its a concern
Old Apr 2, 2004 | 09:12 AM
vipervadim's Avatar
I like Maximas
Kta920 you have a lift in your garage?
i want your garage lol.
if i had a lift it would be so much simpler jackstands don't give enough raise.
i also have the same issue it took me about 1 hr to take off the damn heatshields. and then i cut myelf so i stopped. the bolts were so rusted that the 14mm didn't even fit but a 13mm fit loosely. maybe this weekend i'll just get a grinder and just grind them off and replace with SS bolts.
for the cat you might want to take of the bolts that connect to the b-pipe i found those easier to turn for some reason and remove the y-pipe with the cat and then get the cat separated from the y-pipe once it's off, that will make it much easier. heat is good too, just watch where you point the torch. also use a hammer to lightly tap the bolts in place to loosen the rust after wd-40ing the hell out of them the day before.
but definitely not a simple project. especially in the NE where we have plenty of rain and changing climates that favor rusting.
Old Apr 2, 2004 | 11:15 AM
Intel's Avatar
All I had to do was cut off the end of the "bolt" (more like rusted nub till the flange is clean) then I pulled off the y pipe and was left with the task of removing the studs. To do this I heated up the cat with a torche and then turned them out with vice grips. Took me a while but wasnt terribly difficult. MAKE SURE YOU WEAR GLASSES rust is not fun in your eye.
Old Apr 2, 2004 | 11:20 AM
Prophecy1's Avatar
LIQUID WRENCH is a better remover than WD-40 in my opinion.
Also a breaker bar and/or power tools.
Proph
Old Apr 2, 2004 | 11:28 AM
Kta920's Avatar
Yeah my garage is nicely equipped dad bought it for his Honda S2000,but since that's in hibernation,it's perfect for a 17 year old kid to fix up his Maxima dream car (not some ricer BS either).
But anyway,I think later on today once I get out of work I'm gonna torch 'em off.Hopefully that will work.And I'll get rid of my cat and get a new one.Anyone want a stock 97 cat? It's up for sale after this weekend,or after I find a new one.Wish me luck this weekend,I'll throw up a post on how it went.Thanks guys.
Old Apr 2, 2004 | 11:45 AM
Ladzio's Avatar
good luck! Looks like I will save myself all this trouble and will have someone else do it for me. Moreover I have 95 and who knows what I will have to deal with...
Old Apr 2, 2004 | 11:50 AM
97SEMAXI's Avatar
njmax is right, heat is your friend, heat them up til they are almost glowing red then give it hell, if you have power tools it will make it alot easier
Old Apr 2, 2004 | 12:02 PM
optimus310's Avatar
dude if you have a lift, use a very long breaker bar. If I had a lift I would have done mine in like 30 minutes
Old Apr 2, 2004 | 12:15 PM
Ninos_Maxima's Avatar
be the change u want2C
Yeah I noticed that using power tools is a hell of alot easier to use then hand helds, You can torque anything out with a compressor and a gun without stripping it!!! wOOt!
Old Apr 2, 2004 | 01:31 PM
Neif's Avatar
Are you guys having trouble with the rusted and worn bolts because you live up in the snow with the salty roads?
Old Apr 2, 2004 | 01:50 PM
image's Avatar
Yea they are. Also you have 276 HP with just a Y Pipe and a CAI?????!!!!
Old Apr 2, 2004 | 01:56 PM
BOSS
......You guys have any suggestions on getting them off??
= HEAT GUN
Old Apr 3, 2004 | 08:41 AM
Kta920's Avatar
No!!! My buddy was just messin around with that.He has no where near what he claims either.Its just a website...not true,TRUST ME! If I had 276hp I'd be in heaven.But yeah,all this snow and salt has rusted my bolts underneath my car to round nubs.Theres no notches to even fit an air wrench on it.So I'm torching them off in about 20 minutes.Then I'll probably have to buy a new cat or tap some new holes in it so the bolts will fit.Wish me luck!
Old Apr 3, 2004 | 01:52 PM
Kta920's Avatar
F***in ****ED!! Tried everything today.I woke up early and went to work on my car.Tried torching:nothing.Tried a freakin sawzall:nothing.NOTHING would get those bolts off.Now I can't drive my car cuz there's a huge exhaust leak and I sound like a Honduh with dually mufflers.Goin' to my last option,cutting the whole exhaust off and re-doing the whole thing.Now the only problem I have is getting a B-pipe and muffler with my empty pockets.I have $25 in my pocket and that just went towards the cat.Can someone help me out and sell me a b-pipe?? I posted a "WTD" in the For Sale 4th Gen forums,but no one ever replies.Can someone who looks at this sell me one,please.I might have the muffler section all lined up.I have the Y-the cat-the muffler...need the rest.Please someone help,I miss my Max!
Old Apr 3, 2004 | 02:03 PM
skiboarder72's Avatar
Yea they are a royal pain, mine too me and a friend (thx) 12 long hours.... had to get out the metal saw...
Old Apr 3, 2004 | 02:14 PM
JeEvE's Avatar
I was working on installing my y-pipe. I was able to get one nut loose with pb blaster and a breaker bar. The other nut just stripped in the socket. Is there any mini torch or something I can get? I called some places around here and they want $35-65 to just replace the nuts for me and I dont really want to do that.
Old Apr 3, 2004 | 03:14 PM
liqidvenom's Avatar
brotherhood of tq
thats y i new mine were rusted after installed my cat back so i just bought a new cat and that made the whole install easy. I wish i had a lift though....
Old Apr 3, 2004 | 06:15 PM
VQuick's Avatar
Chassis Freak
If you have a damn lift in your garage, why don't you have air tools? With a compressor you could get those bolts off easily.
Quickywd01
Sep 21, 2016 09:36 PM
RealityCheck
Oct 2, 2015 06:34 PM
lrb6805
Sep 17, 2015 04:49 PM
Violator
Sep 9, 2015 10:14 AM
