After Knock Sensor Replacement
Old Apr 2, 2004 | 12:31 PM
unixsvr4's Avatar
I have a quick question, Once you replace Knock sensor, after how long you can start feeling the difference. I took my car to AutoZone, the guy hooked up his hand held computer and the only error on my car was " Knock sensor Maulfuntion" I just replaced it today. I was just wondering. Thanks
Old Apr 2, 2004 | 12:32 PM
DAVE Sz's Avatar
Hooooooonda.....
A few days or couple hundred miles. Then again you might not notice any difference at all.
Old Apr 2, 2004 | 12:53 PM
knight71's Avatar
Did he reset your ECU?...I felt a huge difference, drive your car hard and you feel a difference in about 2 days.
Old Apr 2, 2004 | 01:16 PM
mansurxk's Avatar
i felt it once i reset the ECU, i could chirp immediately, which i couldnt do before, could be in my head htough, but my gas mileage went up immediately, from 14 to 19
Old Apr 3, 2004 | 04:56 AM
unixsvr4's Avatar
And how do I reset ECU?
Old Apr 3, 2004 | 04:57 AM
s0ber's Avatar
Its in the FAQ
http://forums.maxima.org/showthread.php?t=104931
Old Apr 3, 2004 | 07:13 AM
Stephen Max's Avatar
I felt a difference immediately. It was like night and day. It depends on what octane number gas you're using, though. If all you burn is 87 octane, then you won't notice hardly any difference, because the ecu will retard timing when the new knock sensor detects detonation. With 89 octane you will probably notice some difference, probably not too much, but with 91 octane or higher there should be a significant difference. That is, if your old knock sensor was truly bad.
Old Apr 3, 2004 | 09:54 AM
sk24iam's Avatar
Do they charge yout to check for codes at autozone?
Old Apr 3, 2004 | 10:19 AM
2naboy's Avatar
you should feel the difference immediately regardless of what octane you are running. I have done this twice with 87 octane and 97 and both times I felt the difference when I flored it.
Old Apr 5, 2004 | 05:05 AM
Sometimes my wife puts 87 octane in her 5th gen, and I immediately notice the difference in power. It feels like my 4th gen did when it had a bad KS. The most noticeable increase in power after replacing a bad KS is in the mid rpm range and at partial throttle. That is when the ignition timing is advanced the most and is most susceptible to knock-induced timing retard. Some knowledgeable people here maintain that the ecu doesn't use knock sensor information at WOT but reverts to timing tables based solely on rpm and airflow. The FSM does hint at that without really saying so.
Old Apr 5, 2004 | 05:14 AM
DemonSpawn's Avatar
Nope, it's free. However, it's not a diagnostic machine that they use ... it just pulls your ECU codes and they tell you what to buy from them
You can find OBD-I and OBD-II scanners on the internet. Some even come with really nice software for your PC so you can do running diagnostics on your car as well as pulling/resetting codes.
Here's a few links if you want your own (very worth it IMO):
http://shop.store.yahoo.com/rodi/autxrayezobs.html
http://www.obdii.com/
http://www.mobileplanet.com/product....pf_id=MP181503
http://www.dervman.com/obdii.htm
Old Apr 5, 2004 | 05:51 AM
ChrisA's Avatar
i agree grade of gas plays a large role in it.
when i changed mine i know for a fact i had super in it and the difference was incredible. since that time i know my wife has put 87/89 in it and it is still improved signifigantly but performance has dropped. i would not go as far as to say running 87 is similar to when you have a bad knock sensor, no knock sensor is much worse performing than 87 with a good KS. the improvement is just gonna be less obvious.
by the way, my improvement was immediate after changing KS. i changed it, reset my ecu, and HELLO.
CorollaULEV
30
Aug 9, 2021 08:11 PM
kjlouis
Nov 24, 2018 06:09 AM
maxinout93
Oct 27, 2015 01:29 PM
Maxboy23
Aug 21, 2015 11:02 AM
maxinout93
Aug 20, 2015 02:17 AM
