Found out how to change color of ignition ring
Old Apr 2, 2004 | 07:37 PM
Terran's Avatar
This may be common knowledge but I thought I saw a thread wondering how to do it. But anyway, as I was making my guage lights blue I looked at the bulb for the ignition ring and it's a just a 74. I just ordered a blue one from www.superlumination.com (after trying to find them at some local parts stores).
Old Apr 2, 2004 | 08:17 PM
Tyrexx's Avatar
Originally Posted by Terran
This may be common knowledge.
+1
yes sir, this is a VERY easy mod, I have a blue LED, it lights up the entire ring very well.
Old Apr 2, 2004 | 08:51 PM
Terran's Avatar
yeah, just thought I'd let whoever it was that was asking know about it.
ManualMaxima's Avatar
5th Gen till she dies!
i have a bkue led in there too. i also just did my blue interior turn signals too with the same bulbs!
Old Apr 2, 2004 | 09:44 PM
bigx323's Avatar
thanx for the info, i was actually just wondering about that
Old Apr 8, 2004 | 10:16 PM
maxima_se007's Avatar
Yeah, I tried a blue incandescent #74 bulb in my keyring but I didn't like the results. I searched around on eBay, and found some blue led's which are mad for the #74 bulb's socket. Just search for "blue led 74" (or whatever color you want). The username of the guy I got it from was ctlumination, if you wanna look for someone who is a good seller. I'm thinking it was around $2.00 including shipping. Looks great!!!!
Old Apr 8, 2004 | 10:21 PM
Nismotic's Avatar
Always sunny in philly
where is it located again? i might just do this
Old Apr 8, 2004 | 11:57 PM
BadFish's Avatar
Really easy mod, i didnt even use another 74 bulb. The first day, or should i say night, that i had my max i took the ignition ring out and pulled the little condom off the bulb and put a sliver of red bulb cover material i had left over and it worked like a charm. my ignition ring has been bright red for the past year and matches my red/black theme perfectly. i may just get a 74 red bulb now that i see everyone doing it so that itll shine brighter. maybe not..
Old Apr 9, 2004 | 07:37 AM
Who's Avatar
Who
I haven't changed my bulb as yet but I did make the ring alot brighter. All you have to do is tape a ring of aluminium foil around outside of the plastic difuser. You'll have to remove the black tape near the bulb area before putting the foil. On average I think it got 2-3 times brighter. I think I also did some other stuff with the foil but I can't remember right now....when I'm changing the bulb I'll probably do a write up.
Old Apr 9, 2004 | 08:51 AM
BadFish's Avatar
ring of aluminum foil + #74 LED bulb = even brighter
Old Apr 9, 2004 | 09:13 AM
VQuick's Avatar
Chassis Freak
How do you take the ignition key ring out?
Old Apr 9, 2004 | 11:28 AM
Terran's Avatar
You don't take it out, just follow these insructions for gettting the guages out (http://www.geocities.com/amixam69/ni...ash/index.html) until you take apart the steering column cover and you'll see some wires going into a white plastic thing on the side of ring. Just twist the bulb holder and it should come right out.
Also, it definetely doesn't come out bright enough. I was going to change the bulb out for an LED, but I think I'll try that aluminum foil thing first (that's good thinking ).
acw
Aug 13, 2015 12:50 AM
acw
Aug 7, 2015 04:20 PM
RealityCheck
Aug 5, 2015 06:18 AM
