Idling Problem
Old Apr 7, 2004 | 01:51 PM
Subzero's Avatar
Idling Problem
I have a 99' with A/T, What would cause the idle to bounce around at 500-1000 rpms (dips and stays at 500 rpms) when coming to a stop? And it also sits and idles at 500 rpms and the whole car vibrates, but only when in drive or rev (under load) and stops doing this when put in to nuetral or park? And seems to do this more when the car is hot not cold? Oh yeah no check engine or trans lights. Thanks
Old Apr 8, 2004 | 04:17 AM
Subzero's Avatar
Noone has had this problem?
Old Apr 8, 2004 | 04:57 AM
95Max's Avatar
Is the needle stable at 500 or does it hop around. If it hops check you idle air sensor. HAve you tried cleaning your throttle body?
Old Apr 8, 2004 | 11:47 AM
sagamax's Avatar
Give me a Bud Light Holmes
i recently cleaned my throttle body and air filter and i am having this problem now. i checked all the hoses and they are all tight. no air leaks. im stumped????? what is the idle air sensor????
Old Apr 8, 2004 | 12:27 PM
95Max's Avatar
IAC is next to the TPS and control idle speed
Old Apr 8, 2004 | 01:19 PM
sagamax's Avatar
tps???????
Old Apr 8, 2004 | 01:56 PM
Subzero's Avatar
It drops to about 500 then goes to 1000 then drops to 500 and usually stays there (when under load; in drive or rev) maybe tranny hanging up?
Old Apr 8, 2004 | 02:01 PM
fearthegecko's Avatar
Most Perverted Member of the SE-L Club
did you just do a y-pipe install? I had one put on, and mine is doing something similiar to this.....
Old Apr 8, 2004 | 02:14 PM
95Max's Avatar
Ok here we go
TPS= throttle positioning sensor
More info please. when I say hopping around I mean 500, 600, 550, 650, 500...you get the idea. If it does test/replace the IAC Have you cleaned your Throttle body? Do you have a K&n type filter?
y-pipe...if it does this after you install a y-pipe you have most likely damaged an O2 sensor.
Old Apr 8, 2004 | 02:26 PM
or had a damaged o2 sensor beforehand.......
Old Apr 8, 2004 | 08:53 PM
sagamax's Avatar
well i didnt do nething and my idle is back to normal i guess some left over oil from that k&n recharge kit was still on the filter and was messin wit my idle i guess it dried up now
97_GXE
20
Sep 17, 2015 08:12 PM
lrb6805
Sep 17, 2015 04:49 PM
NissanNismoZ
Sep 12, 2015 07:30 AM
