Is it possible to clean the TB incorectly.
Old Apr 9, 2004 | 03:20 PM
thekenone's Avatar
I just got finished cleanin the throttle body with Stp TB cleaner. now my car idles higher than before.around 1500-1700. if i press the gas a couple of times it will go down to 700. do i need to reclean it? or did i f*** someting up?
Old Apr 9, 2004 | 04:18 PM
happyricefob's Avatar
V^___^V
no it is not necessary. if your engine is cold, and you start up your car, your idle should be around 1500. after the engine is warmed up, it should go down to 750. it's not a big deal, i wouldn't trip.
Old Apr 9, 2004 | 04:21 PM
icefishing's Avatar
you might of messed somthing up, the way it sounds. But it don't think you messed up so bad to were you cant just open in back up and fix what ever you did wrong.
Check to make sure nothing is loose in or around it. But you got me on that one. maybe it is the spring on the outside (left of the throdle body) that opens the throtle plate. check that out.
Old Apr 9, 2004 | 05:15 PM
mansurxk's Avatar
if he left residue around the butterfly plate, its possible it might be stuck slightly open maybe? it might be sticking possibly? dunno just a thought
Old Apr 9, 2004 | 05:44 PM
thekenone's Avatar
i went back out and re cleaned it. still a little dirt in there but didn't seem sticky. also i have driven on the freeway for about 30 min.
Old Apr 9, 2004 | 06:06 PM
charancon's Avatar
I've got pretty much the same situation, problem is, I wasnt the owner before the cleaning so I dont know how it behaved before that. It seems pretty normal if you ask me. If anything, I would suspect the AICV, you could try cleaning that as well, look in the how to section...
Old Apr 9, 2004 | 06:36 PM
s0ber's Avatar
After I cleaned my IACV/TB the cold idle was way higher than before, I dont see it as a problem tho as it drops down when its supposed to...
Old Apr 10, 2004 | 07:58 AM
Jatan's Avatar
Mine was high too after cleaning the TB and the IACV. It went down after a week and it became normal after about 2 weeks. You can adjust the idle with the screw, but I didn't want to mess around with it
After the cleaning, the car used to start up 1300-1400 cold and now it's down to 1100. It would idle at about 900 and now it's around 750
Old Apr 10, 2004 | 08:17 PM
thekenone's Avatar
cool kinda hope mine will drop back down 2 750. but after cleaning it and putting on a few new grounds it doesn't bounce around at all wherever it decides to idle at.
aw11power
Oct 10, 2021 04:57 AM
Apr 16, 2020 05:15 AM
BobTX10
Oct 7, 2015 08:43 AM
fx4five
Oct 1, 2015 04:58 AM
