check engine light ON after INTAKE installation
Old Apr 11, 2004 | 01:22 PM
Jonny98max's Avatar
i tried reconnecting all my sensors back....and i also tried reseting the ECU by disconnecting the battery and resetting it by(clockwise, 2 sec, counterclockwise... etc.) but the CHECK ENGINE LIGHT is still on....what can i do? the light wasnt on b4 the intake installation
Old Apr 11, 2004 | 02:09 PM
2 Da Max's Avatar
its probably your airflow sensor my cel is on because of that too
Old Apr 11, 2004 | 02:28 PM
DAVE Sz's Avatar
Hooooooonda.....
Did you bother to check the codes or did you just reset it? How are you supposed to know what it was if you didn't check? How are we supposed to help you if you don't know the problem?
Old Apr 11, 2004 | 03:25 PM
SkinnyMax's Avatar
maxima no more
if your maf (mass air flow sensor) gets a lot more air than expected it will throw a code, make sure the code is related to the maf though
Old Apr 11, 2004 | 08:29 PM
Jonny98max's Avatar
the light dint turn on till i got my intake installed so its gotta be the intake thats making the light go on
Old Apr 11, 2004 | 09:02 PM
DAVE Sz's Avatar
Hooooooonda.....
It doesn't have to be but I guess we'll never know. Make sure you go over everything a few more times to make sure everything is fine, the MAF and IAT connectors, loose hoses, any missing hardware that might now be inside th engine.
Old Apr 11, 2004 | 09:04 PM
Capitone's Avatar
It is obvious that the problem is more than likely your intake. It is not uncommon for new intakes to throw codes, HOWEVER, as someone already mentioned, check the code first and MAKE SURE that the code is MAF related. Check the stickies for directions on how to read codes and what they mean. Make sure the wire to your MAF is connected as well (sometimes the connector doesn't seat all the way). Only after you do this, will you have a real idea of whether you've got a real problem or a common intake addition code. Do the aforementioned, then come back to us for advice.
Old Apr 12, 2004 | 03:49 AM
mzmtg's Avatar
Minister of Silly Walks
You reset the light without recording the code?
Try again.
MaximaDrvr
Aug 19, 2015 08:20 PM
beboski
Aug 16, 2015 05:23 PM
Flores94
Aug 11, 2015 12:53 PM
bassmann
Aug 3, 2015 07:53 PM
