View Poll Results: WHICH INTAKE WOULD BE BEST
CAI ( Injen Clone with K&N filter)
54
32.93%
Hybrid (Frankencar)
40
24.39%
Popcharger (JWT)
35
21.34%
Drop in K&N
35
21.34%
Voters: 164. You may not vote on this poll
YOUR opinion on an intake, frankencar, injen clone or POPcharger? Opinions please
Old Mar 18, 2005 | 11:28 AM
  #41
deezo's Avatar
Originally Posted by mattC
If you want the sound, get the cheapest damn thing you can get.
If you want the performance, save and get a supercharger.
I don't know anything the current intakes out, i need a refresher.
edit: now that i read it again, i would just go with drop in k&n filter.
So you moved to PVD huh? Are you going to school there now?
Old Mar 18, 2005 | 11:34 AM
  #42
DR-Max's Avatar
Isn't this in the stickies already???
BTW....I vote for hacked airbox, its not in your poll list.
Originally Posted by Dave B
I'll make this easy hopefully we'll never have to see any of these posts EVER again
1) The Frankencar Intake is just like the Stillen/JWT "POP"-style intakes except that the Frankencar/Berk intakes comes with a midpipe that replaces the OEM resonator that sits inbetween MAF sensor and throttle body. The Frankencar/Berk intakes have gotten the nickname "hybrid". A Stillen/JWT or any other POP setup can be converted to a hybrid by simply adding a midpipe. There is nothing remotely special about a Frankencar intake. Nothing.
2) A midpipe has yet to be documented to make any power gains, but it does introduce quite a bit more intake noise and a generally deeper sound. Most owners tend to like this induction noise under 1/2 to full throttle. The sound emmulates the sound of an Acura NSX.
3) The Injen intake is not a CAI. It pulls air from the drivers side front portion of the car just to the side of the raditor. IMO, this is probably the worst place to be drawing air. Also, the Injen piping is routed close to very hot engine components (manifold, head, block, tranny) which will heat soak the nice shiny intake piping.
4) The Cattman/Place Racing/Warpspeed CAIs are the only true CAIs on the market. These setups pull air from an area that is sealed off from the engine bay. These intakes pull in ambient air. These intake require cutting a 3.2" diameter hole near the battery to route the piping. Many owners are afraid to cut into their car for fear of resale problems. The truth is a good cut is not noticable because the hole sits in a location that is shielded by the battery and wiring harnesses.
5) The hacked airbox is when you cut out the lower airbox to bring in more air. This results in more sound, POP intake power, and the introduction of hot engine bay air.
6) The POP/hybrid/hacked airbox intakes are assumed to make better upper rpm power at the expense of lower rpm power. "Boggy" throttle response, especially in hot weather is common with these intakes. The lack of throttle response is most likely due to removing the pressurization effects of the stock intake tract and drawing in hot engine bay air.
7) The CAI intakes are assumed to make better lowend and mid rpm power. The CAI intakes don't seem to suffer from the "bogginess" problems because of the 14" longer intake tract which is able to store a column of air and in a sense keep the air pressurized, less turbulent, and cooler.
8) Dynos and track results have proven that all the intake setups POP/hybrid/Injen/CAI/hacked all perform basically the same assuming the air outside is cold and the engine is cooled off.
9) Hybrid/POP/hacked/Injen intakes pull in underhood air therefore in the summer these intakes can be drawing in air that's over 140 degrees. A CAI will be pulling in ambient air. It has been shown that the engine bay air cools down to near ambient once the car is moving at 30mph+ for a few minutes. The problem is the temp sensor and knock sensor typically will detect the extremely hot air coming in therefore from a stop the car's acceleration can feel weak in 1st gear. At the track this can cause a much slower 330' if the engine is not cooled.
10) In the end it comes down with what you're will to pay and what kind of driveability you want.
Dave
Old Mar 19, 2005 | 02:22 PM
  #43
MaxGordon7's Avatar
When i just had an intake install i just felt like it redline/shifted harder, It takes the laggyness out of it. im sure its not hella hp by its self but when added with other exhaust parts im sure it adds. It has to add hp, other wise why waste money on it!
Old Mar 19, 2005 | 07:14 PM
  #44
grey99max's Avatar
LandShark has Cosworth
A Minority Opinion For INGEN - from my VQPOWER comments last year.....
Yeah, I just decided to put an Ingen on my '99 GXE, even though some folks call them a "warm-air" intake. Well, it did install as advertised, but since I was still wondering about the "warm-air" label, I put a Radio Shack outside digital thermometer probe inside the main tube, through the valve cover scavenger hose. Guess what? Air temp in the Ingen went to over 122 degrees F with outside air of 74-78 degrees! Airplanes can't take off when the air is that hot!
So I stared at the engine compartment for a while, reversed the lower tube to drop the filter lower, then took off the driver-side lower splash-shield, and intake temp dropped into the 90s. Better. Then I covered the filter on the top with a plastic bowl, to keep the hot radiator air away from the filter. Now intake temp drops to 4-6 degrees above outside air temp! So, now it acts like a cold-air intake, and the car feels much more responsive....
http://forums.maxima.org/misc.php?do...g=0&forumid=9#
The car has much better throttle response. Ingen now sells the filter covers to do the same thing... This works much better than a hacked airbox with a K&N filter that I tried first. Intake air temps were over 130 degrees on the dyno! Now intake is 5-10 degress over outside air temperatures.
grey99max - maxima.org
Old Mar 27, 2005 | 06:15 PM
  #45
suicidalspd99
I don't think any of that stuff matters. I have the Inken intake. But with a mass air flow sencor, it compensates for cold and warm air. It also does not let any more in than before. So i guess if you think about it it useless with our mass air flow sencor. But if you could eliminate or have and afterarket mass air flow sencor then it might work. BTW if you have a mas air flow sencor or know of a brand. Let me know i'm seaching.
Old Apr 12, 2005 | 03:29 PM
  #46
86maxima96's Avatar
I Broke OT
hmmm, is he right? This makes sense, does the MAFS just compensate for it and run the same, just as though it was a cooler day and compensate with fuel? It doesn't seem right. Wouldn't Injen and Cattman have realized this and done something? Help me make sense of it! I have an Injen and it feels like it really pulls after about 3300, so it must be doing somethin other than makin noise, right?
Old Apr 12, 2005 | 03:32 PM
  #47
Zack342's Avatar
why is this thread still alive
Old Apr 12, 2005 | 05:59 PM
  #48
Ruiner6's Avatar
i used the hybrid intake setup with my warpspeed y-pipe, i'm unsure of the exact gains but i can tell u that the two together produced alot of extra hp. i would go with a hybrid setup because it gives more power throughout the entire rpm range rather than just at the top or bottom as cai's and popchargers do
Old Apr 12, 2005 | 06:42 PM
  #49
Prophecy1's Avatar
Place Racing with the drilled hole for the win. I got one and the next few days I will show you why. I put mine on and its a beast with great flow and the installation was perfect, I mean the CAI was enginneered so well to fit our cars.
Proph
Old May 19, 2005 | 10:13 PM
  #50
dawalkster's Avatar
is craving Bojangles
i use a hybrid intake setup because it frightens small children when i drive through the neighborhood
it also has caused temporary hearing loss when a friend of mine was bashing my import (mustang owner ) so i had him listen to my intake by putting his head right over the filter nearly resting his head on it. then i revved it hard and he had nothing to say about my vq after that.
about the intake debates though- they're really nearly pointless. i mean only a few hp seperates one type over the others; such an insignificant amount that you couldnt feel the difference.
Old May 20, 2005 | 06:16 PM
  #51
RA030726's Avatar
I'm nutty for Nissans
temp has nothing to do with the mass air flow sensor.
Old May 20, 2005 | 06:36 PM
  #52
maximazation's Avatar
just reverted back to my stock intake because my HAI just made noise and made me lose a lot of low-end power...
Old Jun 30, 2005 | 09:57 PM
  #53
enomik-1's Avatar
I have an Injen intake and Ive been reading that stock is better.. but I honestly
felt a differance after install. I love it. Oh yeah Ive beaten a 4th Max with
a place racing CAI... Bairly by my back door, but I beat him 3 times.
Old Jun 30, 2005 | 10:16 PM
  #54
NmexMAX's Avatar
dot dot dot ...
Zack already proved the crappiness of a midpipe on a 4g ... Feeling and seeing #'s are different things. This b!txh as.s thread is almost over a year old. Zack, POP is my chioce, proven gains and no funky curve, at the expense of a little low end.
Old Jul 15, 2005 | 08:29 PM
  #55
9maxse5's Avatar
iyo
in your opinions what is the best combo...no matter the price?
Old Jul 15, 2005 | 08:35 PM
  #56
99Automagic
Anyone have the link to the thread that zack started, with the dyno charts showing the diff between stock and after market intakes? Been looking for an hour now. Maybe I'm going blind.
Old Aug 10, 2005 | 06:19 AM
  #57
Iron Scimitar's Avatar
Tha Snatcher
i found a similar thread that i have bookmarked @ home. I'll try to find it now.
Old Aug 10, 2005 | 09:59 AM
  #58
DR-Max's Avatar
There you go:
http://forums.maxima.org/showthread....ght=FRANKENCAR
Old Sep 18, 2005 | 08:45 PM
  #59
Fulltone74's Avatar
I believe for most modern cars, it is hard to improve upon stock intakes, unless there isn't a concern with a major increase in intake sound.
Design engineers that work for the big auto companies these days have access to massively powerful computer workstations for computational fluid dynamics modeling. These computers can be used to derive the best layout for an intake under a variety of engine loads, air flow, temperature, altitude, etc. The shapes of the intake parts may look highly convoluted, but there is generally a reason for the odd appearance.
Old Sep 18, 2005 | 11:33 PM
  #60
Fulltone74's Avatar
Old Sep 19, 2005 | 05:09 AM
  #61
Zack342's Avatar
This is NOT true. As someone with a Mechanical Engineering Background I can assure you power is not the main concern of these designers. They are more interested in sound reduction, reliability and effiency. A Hi-flow intake will intorduce more air into the engine, More air requires more fuel. More fuel increases gas consumption. The engine will make more power no doubt but at what cost.
Old Sep 19, 2005 | 08:36 AM
  #62
Dave B's Avatar
Not DAVEB the parts guy
If it sounds like you're going faster, your brain will think you're going faster even though you might actually be slower. Various intakes on the Maxima make a lot of noise and some vibration above 3500rpms. All of that can confuse the senses.
Old Sep 19, 2005 | 12:35 PM
  #63
XeroX's Avatar
Hella internets
Why isnt PR type intake on here? isnt that the only REAL CAI?
Anyways, altho it probly isnt anything to rant about, im sure a real CAI with the filter inside the fender has to provide SOME kind of gain, regardless of how much...it does do something....its common sense....
Old Sep 19, 2005 | 04:28 PM
  #64
Zack342's Avatar
Common Sense doesn't apply to this situation.
Old Sep 19, 2005 | 04:37 PM
  #65
99Automagic
Who the fok started this thread?!?!?! ^^^^
Old Sep 20, 2005 | 02:06 PM
  #66
AGRECORDS
ok i'll say this once! i have the BLITZ SUS filter with a JWT popcharger and a crome finished midpipe OFF EBAY....... definitly more power than the stock air box even at low rpms and way more at mid to high rpms... but trust yourself.....later
Old Oct 24, 2005 | 09:14 AM
  #67
eyesack killa's Avatar
DO NOT BUY AN EBAY INTAKE!!!!! my friend johnny has an 89 accord, bought an injen style intake offa ebay for 50 bucks, and when we went to install it, we found that the bends in the piping were EXACTLY OPPOSITE of where they should have been! needless to say, we still cut the pipe to pieces and duct taped it together until we went to home depot to find some rubber hose connectors.
I have a 95 auto with an Injen. i chose to not get a PR style b/c i don't feel like cutting a hole in my fender and like Majik said "how much air can the PR CAI pull in when its tucked in by the fender." that was one of the first things that crossed my mind. The Injen intake sounds niiice, and i can honestly feel pretty noticeable gains at 35000+rpm. Injen also gives you free liscense plate frame and decals... These, if used correctly, can achieve gains of 30+ hp/torque!
Old Oct 24, 2005 | 11:01 AM
  #68
NmexMAX's Avatar
dot dot dot ...
PR style Ebay intakes are good.
Your accord friend needs to do a little more research, ask for pics etc so he doesnl;t get
Injen intakes are
Old Oct 24, 2005 | 11:37 AM
  #69
Mr.Duck's Avatar
wow the 2 posts above nmex are just stupid... it has been dyno proven that the stock midpipe produces the best hp. Also the injen design doesnt make any sense, ok lets put a CAI RIGHT NEXT THE ENGINE AND THE RADIATOR! so smart!
Old Nov 15, 2005 | 12:16 PM
  #70
95 maxima se's Avatar
Silver Tooth S2K 9k FTMFW
i had a bomz intake it was ok but then i bought an injen CAI sooooooo!!! much better than bomz, thts what i think.
Old Jan 29, 2006 | 07:29 PM
  #71
PFCGlass's Avatar
I bought and installed an Injen CAI. Been using it for 2 months now, and I love it. Makes a great sound, and I felt a HUGE power gain after install around 3500 RPM range. And Injen is dyno proven, which is another one of the reason I purchased it--I wouldn't hack at my car or start cutting at it if I wasn't positive it wasn't going to get some type of major benefit, so this way I felt more safe, since I do plan to sell it after I finish college in 2~ years,
Old Feb 5, 2006 | 08:15 PM
  #72
99grnmaxgxe's Avatar
I have a cone filter adapted to the MAF sensor and MAN! do I miss the low end power! When I have time, I'm going to put the stock intake back on and enjoy the torque!!!!
Old Feb 7, 2006 | 12:00 AM
  #73
Turiman's Avatar
got my Place Racing CAI for 65 bucks (what a deal), and since then im in love, sounds great under heavy acceleration lets say +3000rpm, and is way better than my old stillen popcharger, btw common sense has something to do in this situacion: popcharger = engine bay temp air, PR CAI = outside temp air (i guess is colder than under the hood)... but hey this is just my opinion
Old Feb 7, 2006 | 12:08 AM
  #74
Turiman's Avatar
oh and other thing, some time ago when i had my auto max (99) stock i street race a friend who has a another auto max (96), i got him by 1/3 car length... some time after that we race again but we both with upgraded intakes: PR CAI (me) vs Injen "CAI" (friend) and this time i left him for about 1 car length, of course these are ghetto measurements, but at least true story
NOTE: both races started from 0 miles and ended about 80 mph
Old May 28, 2006 | 07:23 PM
  #75
ethnic6's Avatar
doesn't matter what u do, if u like noice go with the aftermarket, but for the most part the best intake filter is K&N...
Old Jun 6, 2006 | 12:33 PM
  #76
95bluse's Avatar
this thread comes back on a yearly basis...priceless
Old Jun 6, 2006 | 04:48 PM
  #77
95_Maxima_5spd's Avatar
lol @ all the mixed opinions. i used to have a civic (go ahead and bash).....but anyway did a custom setup using an AEM V2 system and a little extra 3" aluminum piping from home depot and a K&N cone filter. i first installed the V2 as normal and took some measurements behind the front bumper. if anyone knows anything about the 92-95 civic front bumper, you will know of the black pieces that fill the gaps...well if you cut that out it leaves a big hole right in front of where the filter for the regular V2 intake would sit. well i did some cutting and a lot of measuring, etc. and ended up with the filter right against the hole in the front bumper pointing forward. yes i know it sounds afro-engineered, but it sounded amazing and i felt a fairly good gain in power out of it.
the point of this being, if there were a way to do this to my Maxima, i would most definately do it
Old Jun 6, 2006 | 06:34 PM
  #78
Check DRMax's intake setup in his cardomain.
Old Jun 7, 2006 | 01:10 AM
  #79
DR-Max's Avatar
If that is so, then why did my car run better with an HAI setup during cold weather days and ran like a dog during hot summer days? BTW, I don't have that crappy HAI setup anymore. Fact: cold air = denser air = better performance. Also, dyno graphs prove that whenever you add a power-adder to your car, it throws of the air/fuel ratio. So there goes the theory of the MAF compensating for things.
Old Jun 9, 2006 | 09:30 PM
  #80
97MaximaSE97's Avatar
Man there are too many opinions on intakes. I heard if you get some exaust mods like y-pipe and cat-back the intake system doesn't lose low end due to a more free flow setup. I don't know I was thinking of a JWT popcharger put onto my stock mid-pipe. Would I lose much low end if I had the JWT with a y-pipe or catback?
