Only one of my window sprinklers does NOT work, why?
Old Apr 17, 2004 | 04:44 PM
BOSS
when inside the car, the left sprinkler works full force, spitting out windshield fluid like crazy. The right one however does not work at all. I double checked under the hood and there seems to be no problem. All the little hoses are connected properly.
Also, I thought it might be stuck so I went and cleaned the two holes in the sprinkler with a needle and still nothing. It's weird, the hose first goes into the right, and then the left sprinkler, right? right. So, where is it divided up into two hoses? Does the big hose actually have two seperate tubes inside?
Old Apr 17, 2004 | 05:15 PM
maxdout00's Avatar
are the little holes clogged up with wax possibly
just my $.2
Old Apr 17, 2004 | 05:35 PM
BOSS
no, the holes are not clogged, I already tried unclogging them with a needle and no help
Old Apr 17, 2004 | 05:43 PM
patel_anu's Avatar
you might wanna try to unhook the hose from the nozzle and see if water is coming out, if it is than its the nozzle but if not than the hose might be bent somewhere....just an idea
jerrod99_se-l
Aug 27, 2015 08:27 PM
shaunkey1
Aug 18, 2015 10:09 PM
KGMtech
Aug 18, 2015 09:21 AM
kenc15
Aug 5, 2015 08:29 AM
kjm900r
Aug 5, 2015 07:14 AM
