Gauge help
Gauge help
Recently i have gotten a short behind the gauges, i just oredered a aluminum gauge bezel and a set of indiglo gauages, however i ran into a problem getting this gauge cluster off and gettingbehind that plastic to install / look for this short for the interior illumination fuse. After i unscrew the two top screws in the cluster what do i do next to remove this ? any help would be greatly appreciated and thanks
drop ur steering wheel all the way down, then itll help to unscrew that cover on the steering wheel. the bezel will just clip out, its flexible, u pull it out, steering wheel might be in the way, just work around it and bend it, then remove i think 3 screws and unplug the harnesses and the cluster is out. then open the plastic and work all around it, just pop out the clips then the needles are visible, if u dont not play wiht the needles you will have absolutly no problems, so dont do anything dumb.
sorry bout the spelling, im really tired.
220k+ A32
18
Sep 22, 2015 11:39 AM
RWCreative
Sep 21, 2015 11:01 AM
