check engine light is on!
Old Mar 22, 2001 | 04:28 AM
miles2go
yo, i know it could be a number of things but what is your best guess on this engine light check.
it is a 95 se auto with only 63,000 miles on it. i baby this car!
i need a oil change but damn! i do hear a strange noise everytime i start the engine. after it turns over it makes a slight grinding noise. any suggestions before i take it to the dealer? i've been driving it for a week with the light on and it's running great.
Old Mar 22, 2001 | 04:41 AM
Daniel B. Martin's Avatar
Don't play guessing games
Best guess? It makes no sense to play guessing games when you can find out for sure. You will find instructions to do a DTC readout and reset the Check Engine light at:
http://vbxmaxima.8m.com/ecu.html
The DTC "translations" are found at:
http://vbxmaxima.8m.com/ecudecoder.html
Old Mar 22, 2001 | 08:16 AM
matty's Avatar
Grinding is starter
I get a slight grinding when i start it only when it is cold...the shaft in the starter isnt throwing itself back fast enough and its getting caught up on the flyweel...you can get a rebuilt starter but i got A rebuilt at 60K and i have 87K on it now...it must have been a bad rebuilt....on regards to the light...mine is on too im gettin it looked at on friday when i checked what it was it came up to a SMALL gas leak...i got a new gas cap but it still came on after i turned it off again....it must be a small leak back by the gas tank on one of the circulation lines./..it could be alot of different things for yours...make sure you didnt open up the gas cap with the engine running cause it will turn on for that....oh yea i got a 96 se
Old Mar 22, 2001 | 09:44 AM
Loose gas cap
Originally posted by matty
... make sure you didnt open up the gas cap with the engine running cause it will turn on for that...
A loose or missing fuel filler cap will set a Diagnostic Trouble Code, but this is a "two trip" failure. The Engine Control Module tests the fuel system for leaks periodically and won't turn on the Malfunction Indicator Light unless your fuel system fails the test on two successive trips.
Old Mar 22, 2001 | 02:43 PM
BrianV's Avatar
Might want to try resetting the ECU and see if it comes back. If it does then you DEFINATELY have a problem.
Old Mar 24, 2001 | 07:21 AM
miles2go
check engine light off! whew who!!!
you guys are the bomb! i followed the instructions that brian gave me for the ecu and my pulses was 05/05 which meant "ain't a damn thing wrong. so hats off to you guys for saving a single mom a few bucks. i love you. smooches
you guys know your ****!
CorollaULEV
30
Aug 9, 2021 08:11 PM
Justinmc760
Aug 23, 2015 03:10 AM
maxinout93
Aug 20, 2015 02:17 AM
beboski
Aug 16, 2015 05:23 PM
Flores94
Aug 11, 2015 12:53 PM
