Code 1008 please help!!!!!!
Old Apr 21, 2004 | 06:44 AM
unixsvr4's Avatar
Guys
Does any one ever took care of code 1008? Here is the discription from
faq's
1008
The Evaporative Emission (EVAP) Canister Purge Volume Control Solenoid Valve uses an on/off duty cycle to control the flow of fuel vapor from the EVAP canister. Diagnostic Trouble Code 1008 is set when the Engine Control Module (the computer) detects an improper signal through the valve. The problem is likely to be in the electrical wiring, harness, or the valve itself.
Check fuse #58 (10 amps) and replace if necessary.
The CPVCSV is easy to see and reach. It is located in the engine compartment, mounted to the top of the upper intake manifold. Notice the Vehicle Serial number stamped into the firewall. Put your finger on the third-from-last number. Move your finger three inches toward the radiator. That's the CPVCSV. It has one two-wire electrical connector and two vacuum hoses. It is directly above the ignition coil connector for cylinder #5 and has to be removed in order to replace the #5 coil or spark plug.
You may test the valve. This test procedure is performed with the engine off. Remove the electrical connector and both vacuum hoses. Fasten a length of clean rubber vacuum tubing to either nipple. Gently blow through the hose. The valve should be closed and it should be difficult or impossible to send air through the valve. Now use a pair of fused test leads to provide 12 volts to the electric terminals. The polarity doesn't matter. With the solenoid energized the valve should be open and it should be easy to send air through the valve.
maxinout93
Oct 31, 2015 02:04 AM
Kyle Lee Cleveland
Sep 28, 2015 09:01 PM
dshinn
Sep 26, 2015 08:07 PM
zmcneely13
Sep 26, 2015 02:26 PM
