*help*electrical Problem
Old Apr 22, 2004 | 06:03 AM
neptunemax's Avatar
When i turn the light stalk to the middle setting where the bumper lights are supposed to go on along with the corners and the back taillights. The only problem is that nothing lights up . When switching the light stalk from lights off the "Parking Lights" then headlights but i get nothing in between off and the headlights. I had to drive around last night with my ultra bright flashers becuase all of my taillights are out except when braking. Kinda makes it cool to cloak from people on the highway but otherwise im mighty tired of it and i need those lights to come back. I checked the fuse that says Tials under the hood and under the steering wheel and bose fuses are fine. What could the problem be i am stumped. I also got the code for knock sensor and front right heated o2 so that prob means its just the O2 right? thanks guys
Sincerely
Sean
Old Apr 22, 2004 | 06:25 AM
happyricefob's Avatar
V^___^V
you have a blown fuse. the fuse is "t.tail", which is 7.5amp. replace that and your parking/corner light should work.
yes ur O2 sensor is broken, replace that ASAP.
Old Apr 22, 2004 | 06:41 AM
C MAX's Avatar
Sincerely
Sean
you have two fuses that you have to check. the one in the fuse box that you said you checked, now go change the one in the engine compartment next to the battery it's calling your name it's the 7.5 amp one once you find it problem solved.
Old Apr 23, 2004 | 06:58 AM
neptunemax's Avatar
i checked both of those fuses and its neither of them they both look like fine fuses to me. I even put new fuses in their places and it still won't work. Could there be a short or somehitng like that?
Old Apr 26, 2004 | 10:24 AM
neptunemax's Avatar
Anyone Please help
Old Apr 26, 2004 | 10:31 AM
C MAX's Avatar
Anyone Please help
you can test it by putting power to the plus side of the parking light if they light up you could have a bad switch or loose wire. is your alarm hooked up the the light output maybe the connection came loose from there.
litch
123
Jan 4, 2024 07:01 PM
jmlee44
Oct 2, 2022 02:13 PM
user 11122324
42
Jul 18, 2022 03:35 PM
gavin68
Sep 18, 2021 12:36 PM
HerpDerp1919
Sep 29, 2015 02:02 PM
