I'm so confused please help
Old Apr 24, 2004 | 09:54 AM
Shift_my vq's Avatar
OK this post might be semi long. But here's all my problems. About two weeks ago I decided to run my car for ghost codes. I got an egr valve and knock sensor. Ok. I reset my ecu to see if they came back. Started my car and it was super hard to get started. Bam check engine light. I ran the code it said 4-7 crank shaft sensor. So I don't have much time right now or a place to work on my car so I take it to my buddy's shop that's a mechanic and get the crankshaft and knock sensor replaced. I go out to my car this morning and it's ****ing spewing gear oil every where. I shut the car off and dry off underneath it. NO leak unless running. I can't really pin point the leak either because it's up higher than I can see. So i run my ecu for codes and I get 1-1 camshaft sensor,4-7 crankshaft sensor, 10-5 still the egr valve. And yes my ecu was reset after the new part's where put on. Christ it's like I can't catch a break right now. And I usaly have money but I just paid 2k in cash for new dirt bike so i'm dead *** broke. What gives guys is any of this stuff connected or am I just so unlucky right now??
Oh and p.s my car is still hard to start even after the crankshaft sensor
Old Apr 24, 2004 | 10:09 AM
WhiteMax96's Avatar
Of course that your car is still hard to start cause your replace your knock sensor instead of replacing or looking at the EGR valve... a EGR valve who is clogged open will give you a hard time starting.
Old Apr 24, 2004 | 04:25 PM
Ok sweet, I'll look into that next for sure. Any body else have something to say about the rest. And thanx whitemax96
Old Apr 25, 2004 | 12:40 PM
bump come on guys I still need help
Miket2006
Mar 1, 2021 03:55 AM
D Mason
Jun 21, 2016 04:43 AM
AboveDaCloudz
Oct 8, 2015 11:25 PM
06maxima55
Sep 28, 2015 04:29 PM
foodmanry
Sep 24, 2015 12:02 PM
