in need of quick qnswer
Old Apr 24, 2004 | 10:49 AM
QuikSilver71's Avatar
Hey guys,
I have no idea on what the right gap size is for my spark plugs on my 96.
I know its a pretty smiple ? But I cant find the answer anywhere......Help
Old Apr 24, 2004 | 10:53 AM
THT's Avatar
THT
Throbbing member
.044 and be sure to use NGKs
~THT
Old Apr 24, 2004 | 10:55 AM
nostrixoxide's Avatar
.043 (1.1mm)
Old Apr 24, 2004 | 11:07 AM
I have the plugs, they are Splitfire triple platinum ones
Old Apr 24, 2004 | 11:18 AM
Prophecy1's Avatar
NGK Plats or Coppers. Gap to .44. Spend the money and get the plats.
Proph
Old Apr 24, 2004 | 11:22 AM
Magikone69's Avatar
bring those back and get a refund, anything other than ngk will run like crap...trust me i experienced, i once put in some cheap bosch and 4 months later they were toast, they just arent god quality. i got ngk now and car runs gr8, stick with ngk plats for long life or coppers, cheaper but less life than the plats. good luck
Old Apr 24, 2004 | 12:05 PM
THT's Avatar
THT
Throbbing member
The Maxima was designed with NGK plugs in mind. Do not run anything but NGK spark plugs. You could get the platinums or the coppers. The platinums cost a good bit more the coppers but will last for 100K miles (but don't leave them in that long...change them ever 60K or so). The coppers are rated to last for 30K miles but they should be changed every 15K or so. I went with the coppers because even though they have to be changed more often, it's cheaper to change them repeatedly than buy the platinums.
~THT
Old Apr 24, 2004 | 12:12 PM
Ok Ok I changed them for NGK platinums, I am sure glad you guys dont do crack as ill be a crack head for sure.
Ok I see the 3 at the front, now wheres the others???????
Old Apr 24, 2004 | 12:23 PM
Jatan's Avatar
There is a How-To for changing the plugs stickied at the top of the forum The front 3 are under the gray cover and the other 3 are in the back.
Old Apr 24, 2004 | 12:42 PM
THT's Avatar
THT
Throbbing member
The rear ones are a PITA but do it slowly and you won't loose any screws. Or better yet, use a magnetic screwdriver once you've loosened the screws holding the coilpacks down.
~THT
Old Apr 24, 2004 | 01:53 PM
ok all done and running better then ever, just one thing...no.5 AHHHHHHHHHH thats all I gotta say.
Thanks for all your help on this.
Mar 12, 2020 12:06 AM
NewMax03
Oct 7, 2015 08:27 AM
JakeOfAllTrades
Oct 5, 2015 10:40 AM
ef9
Buyer/Seller Feedback
Sep 10, 2015 10:13 PM
