245/45-16 on 7.5" rims
Old Mar 22, 2001 | 04:40 PM
Ax's Avatar
Ax
Does anyone have experience using this size tire/rim combo?
Any rubbing?
Speedometer error?
Old Mar 22, 2001 | 04:44 PM
Jeff92se's Avatar
I'm needing a caw
Question is why? That's pretty wide for a 7.5" rim. ie.. I use a 235-45-17 on a 17x8" rim. And that's about perfect.
For a 7.5" rim, I recommend a 235 at the widest. Maybe a 225.
Old Mar 22, 2001 | 04:50 PM
Ax's Avatar
Ax
Well... I currently run 225/50-16 on a 6.5" SE rim.
I now have some 7.5" 300zx rims.
The 225 are too small, not enough traction.
Old Mar 22, 2001 | 04:56 PM
Sprint's Avatar
try 235
Old Mar 22, 2001 | 05:06 PM
Jeff92se's Avatar
I'm needing a caw
Well the 300z rims come stock w/ 225 so that's the oem recommended size. But I suppose you could go 235s too.
But IMHO traction is much more of a function of the brand of tire vs how wide the tire is. Ie.. a cheap 245 tire will not out grip a 225 top of the line Michelin Pilot series tire. I mean the diff between a 245 and 225 is 20mm=0.86".
Old Mar 22, 2001 | 09:19 PM
CustomMax
At least if you run 245 tires you won't have to worry about any curb, EVER, touching your rims. I have 255's on mine, and I'm running 9 inch rims and the tire overlaps the rims a little. Stick to 225!
Old Mar 22, 2001 | 09:25 PM
CustomMax
Old Mar 22, 2001 | 09:45 PM
Kashoggio's Avatar
you dont want the 245 , it will give your rim/tire that bubble look. The Tire rack sellls 235 with their 7.5 inch tires but you could easily put on 225 or even 215. I am curently looking for 225 for my 17x7.5 rims
coolsun
Wheels/Tires
Nov 13, 2016 05:01 PM
Fbana41
Aug 29, 2016 12:18 PM
Luigi623
Sep 21, 2015 01:42 PM
mikeymouse1995
Sep 18, 2015 06:42 AM
0m3nc0w
Sep 11, 2015 05:21 PM
