weird codes 1105, 1130 and 1165
Old Apr 29, 2004 | 10:46 AM
jillumjill's Avatar
Help!!
Using the OBD II Scan tool from Harrison R&D, the codes pulled are 1105, 1130 and 1165. I can not find any explanation for these codes anywhere. Reset them 2 times. Codes come back after a few miles of driving.
Old Apr 30, 2004 | 08:37 PM
jillumjill's Avatar
bump - someone pls help!!!
Old May 1, 2004 | 06:09 PM
jillumjill's Avatar
bump again
Old May 2, 2004 | 03:58 PM
jillumjill's Avatar
someone must know, pls help!!!!!!
Old May 2, 2004 | 05:47 PM
nitromax's Avatar
j, i'll ck the books i have access to, but what is the year of your car? is it a stick or auto, is it cali or fed emissions? let us know what you're workin with
Old May 2, 2004 | 05:51 PM
Mad-MAX_SE's Avatar
Still kickin'
You really need to look at the stickies at the top of this forum.
Anyway the 1105 code is "Improper Shifting to Third Gear (A/T)"
The 1103 ( i hope you mean 1103, cause there is no 30) code is Improper Shifting to First Gear (A/T)
There is no 1165 code, so i would re-check it
Hope this helps, and PLEASE REAd THE STICKIES AT THE TOP OF THE 4TH GEN FORUM, not everybody is nice on here.
Old May 2, 2004 | 06:24 PM
Mad-MAX_SE's Avatar
Still kickin'
just a thought, if it is a 1106, then it's improper shifting into fourth.
Old May 3, 2004 | 02:26 PM
nitromax's Avatar
p1105- map/baro switch solenoid valve. p1165- swirl control valve vacuum check valve. p1130- swirl control valve control solenoid. these are what i found in code book. no idea what to do about them!!! hope tis helps.
maxinout93
Oct 31, 2015 02:04 AM
HerpDerp1919
Sep 29, 2015 02:02 PM
Kyle Lee Cleveland
Sep 28, 2015 09:01 PM
dshinn
Sep 26, 2015 08:07 PM
