Easy Throttle Question
Old Apr 29, 2004 | 12:33 PM
Socrates's Avatar
I want to tighten up my throttle, make it a little more punchy. Which one is the normal accelerator and which one is the cruise control? I forget
Old Apr 29, 2004 | 12:48 PM
PoePoe2797's Avatar
The inner one is throttle, outer is cruise
Old Apr 29, 2004 | 03:05 PM
_ck69_'s Avatar
What are the advantages/disadvantages of tightening the throttle cable?
Old Apr 29, 2004 | 03:54 PM
Terran's Avatar
No disadvantages as long as you don't over do it. You're just putting it back to factory spec by removing the slack (caused by cable stretch I assume?).
Old Apr 29, 2004 | 06:28 PM
Broaner's Avatar
2060lbs and falling...
PoePoe is correct. The outside line runs to the black circular thing mounted on the fire wall. I believe this is a vacum controlled unit because there is not wire going into it; only a tube.
bryants95max
Oct 2, 2015 12:52 PM
97_GXE
Sep 15, 2015 06:47 AM
Bonka
Sep 14, 2015 11:18 PM
Maxxx10
Sep 13, 2015 03:16 PM
followthadollar
Sep 13, 2015 09:55 AM
