Levoc automatic shifter owners!
For those who installed a Levoc shifter. I want to know how do you make the shifter sit alot lower. Mine sits a little higher than the stock automatic shifter.
Thanks in advance
Eric
Thanks in advance
Eric
you would have to cut the metal rod that it slips over, but i wouldn't recommend it. You might screw somethin up. I wanted it lower too, but i decided that i didnt wanna take the chance. It'll grow on you.
mine was a razo but i think they sit the same. anyways, there are 2 screws on the backside closest to the radio, what i did was push down the shift **** so the screw that normally would go in the bottum one was now in the top one. it still holds securely and sits lower...try it out.
You can cut the outer rod down using a pipe cutter from the hardware store. You would have to cut the same amount off the inner rod. Then you can set the shift **** using the set screws or drill/tap new holds for the screw.
ef9
Oct 4, 2015 08:43 AM
Andy29
Sep 29, 2015 05:32 AM
atriuum
Sep 28, 2015 01:19 PM
