Installing fogs into a 96 maxima
Old May 7, 2004 | 07:56 AM
vsamoylov
ok i want to get some oem fogs for my 96 maxima. the bumper does not have holes for the car. does anybody know if i need to get a new bumper or should i cut the plastic pieces out and put the fogs in there? are the holes the same size as the fogs? did anybody do this? how easy is this cause i dont want to get a se bumper that has the holes for the fogs in it ccause then i would have to paint it so i rather cut holes for the fogs.
thanks
vasiliy
Old May 7, 2004 | 10:56 AM
felixdacat's Avatar
Is your's a GLE? If it's the GXE i think that your car does not come prewired for foglights like the GLE's do. SOMEONE CORRECT ME IF I'M WRONG THOUGH. If you purchase the kit from a dealer ship, it comes with templates you screw into your bumper and it outlines what to cut out. The holes fit the fog lamps. Don't forget that you have to also replace your stalk (which the kit comes with as well). It's not hard at all... All you have to do is read the instructions and take your time. Try looking for the kit... I think Garrand's Nissan sells them pretty cheap than other dealers....
Good Luck
thanks
vasiliy
Old May 7, 2004 | 12:10 PM
Deagle's Avatar
wants the ads to die
Good Luck
Most GXE's do not come with it pre-wired, but if the Comfort Package was added, it is (which I have and am thinking about getting the fogs).
Old May 7, 2004 | 01:58 PM
vsamoylov
what is the website for Garrand's Nissan?
Old May 7, 2004 | 02:50 PM
Jepht20's Avatar
Custom User Title...
the bumpers cut like butter i started off with a dremel to shape it then used a box cutter to slice through.
my gxe wasn't prewired but it's pretty simple to complete the wiring.
Old May 7, 2004 | 03:34 PM
vsamoylov
the whole problem for me is to know where to cut it casue if i cut it too big, i will be screwed.
Old May 7, 2004 | 04:24 PM
Jepht20's Avatar
i'll help you if you get those pics for me of the i30 gas popping solenoid thing
Old May 7, 2004 | 05:09 PM
vsamoylov
i have to scan them now. took me a while to find my manual. whats ur email so i can send them?
Old May 7, 2004 | 05:31 PM
Jepht20's Avatar
you're the man! jepht20@hotmail.com
basically what i did for my bumper is: you know the rough grids on there where your fogs should go? i cut directly around there as close as i could and removed that section. then, i cut accordingly slowly making it the right size. it's really not too bad to do, i found a box cutter was the best bet once you have the shape because the box cutter slices right in and cuts through it easily. just be careful and in control so you don't let it go to far (which can be touched up anyways).
apparently there is some template you can get from the dealer but i didn't bother with it. another member on here Rowan just did it too under my advice and he had no problems. if you need any more help pm me and goodluck!
EuroDriver
Sep 14, 2015 06:08 PM
Dman1989
19
Aug 17, 2015 03:44 AM
Team STILLEN
Aug 10, 2015 04:29 PM
MikesChevelle
Aug 6, 2015 11:36 AM
