painting dash! WHAT PAINT TO BUY?
Old May 9, 2004 | 11:06 PM
Jonny98max's Avatar
since i am out of school now i decided to paint my dash aluminum color....what color paint should i use...i heard DUPLICOLOR.....but what kind? i want a aluminum color with a metallic finish...what do u guys recommend? do i need to put on a clear coat after painting it?
Old May 10, 2004 | 04:05 AM
jdm71488's Avatar
I am hoping you mean the trim on your dash and not the entire thing... either way... yes duplicolor is supposed to be the one to use. if you look in the faqs there is a how-to on it. I know that is not your question, but it may help.
duplicolor makes this wheel paint, which can be used on your trim. they only have a few colors and a clear coat I believe. so it's either silver, or graphite, black, white, or bronze. they also make chrome and gold but its not wheel paint and i don't think that would look all to good anyways.
everyone has painted their dash silver, I think it would be nice to see a graphite one though.
heres some links for ya...
The Faqs Post - #43
Duplicolor
hope this helps...
Old May 10, 2004 | 05:18 AM
sean05's Avatar
Hey guys,
Im thinkin about doing this soon.. Where can i find the paint? How long do i need to wait before i can apply another coat. What grit sand paper do i need? jdm71488 what would a graphite dash look like? I think it would look good but would it show as well? i have a black dash. thanks
Sean
Old May 10, 2004 | 06:39 AM
jdm71488's Avatar
i have heard autozone carries it, or you can get it off their website, but it would probably be cheaper locally at some store. id let it dry as long as it tells you to on the back of the can. graphite would look pretty cool. it wouldn't show as much as silver, but if you looked at it close it would stand out from the dash. if you want it to be seen, id go silver, but the whole smoked look i think graphite would look better.
you don't need sandpaper really, you could, but the surface would hold the paint. just clearcoat after a few paint coats. it should be ok...
Old May 10, 2004 | 06:50 AM
DAVE Sz's Avatar
Hooooooonda.....
If you paint the whole dash good luck with not having an accident every week. Do you have any idea what kind of glare that thing is gonna give off? If you're just painting the parts that can be covered with a dash kit then you should be good.
Old May 10, 2004 | 07:24 AM
superblack98se's Avatar
rustoleum metallic paint silver
Old May 10, 2004 | 10:34 AM
Keith P's Avatar
Look for a vinyl paint. And use TSP to clean the plastic. I ran my dash pieces through the dish washer w/ it.
Old May 10, 2004 | 10:40 AM
Keith P's Avatar
Old May 10, 2004 | 12:09 PM
conz35's Avatar
Use Duplicolor High Rub Wheel Paint. I wouldnt clear coat it because of glare issues. But its your call. I didnt clear coat mine and its fine no scratches so far and its a nice finish. Check out the pics at my domain. http://members.cardomain.com/conz35
Good Luck
Old May 12, 2004 | 05:02 PM
Swangin Chrome's Avatar
primer from pepboys was 99cent and silver from walmart was 94 cent for the dash and brake calipers
http://f1.pg.photos.yahoo.com/ph/dre24k/my_photos
Old May 12, 2004 | 05:39 PM
|Bijan|'s Avatar
UCF Lexus
RICE RICE RICE RICE RICE RICE RICE RICE RICE RICE RICE RICE RICE RICE RICE RICE RICE RICE RICE RICE RICE RICE RICE RICE RICE RICE RICE RICE RICE RICE RICE RICE RICE RICE RICE RICE RICE RICE RICE RICE RICE RICE RICE RICE RICE RICE RICE RICE RICE RICE
Old May 12, 2004 | 06:31 PM
jdm71488's Avatar
Maybe if your pics were better quality, it would do a better justice...
Old May 12, 2004 | 06:36 PM
xelementx's Avatar
check out my site... i think i did a pretty good job....
i used the dupicolor silver wheel paint.. it came out a silver metallic. i didnt use a clear coat because i didnt wan the glossy look.
http://www.cardomain.com/memberpage/470457
o yeah, i also painted the door handle trims.. i just didnt update the pics
Old May 12, 2004 | 09:25 PM
Jonny98max's Avatar
xelementx and conz35...how did u guys remove the vents to paint those...also the winodw switch plate?
Old May 15, 2004 | 09:24 AM
rice? explain??
Old May 15, 2004 | 02:48 PM
Muravchik's Avatar
Swangin Chrome, what kind of primer and what kind of primer and what kind of paint did you use? The paint is good for calipers?
Old May 15, 2004 | 03:16 PM
waveridr85's Avatar
get a dash kit, ive seen both, the aluminum dash kit off ebay looks way better than a painted dash, its only like 90 bux and is worth it
Old May 15, 2004 | 06:03 PM
xelementx's Avatar
after i remover the whole piece ( vent with rear def, hazard) there are about 6 clips holding each vent. 3 top and 2 or 3 on the bottom. just take your time taking the 2 vents out. its pretty selfexplanitory. the window switch plate come right out. i used a butter knife to pry it up. after that, unplug the wire harnest and take the 2 philips screws out. clean the plate and start painting. btw i did not use any primer. just make sure the surface is clean.
Old May 15, 2004 | 06:34 PM
Jonny98max's Avatar
how did u take off the side vent plates....not the one in the center....the side ones....(passenger and driver side)
Old May 15, 2004 | 07:42 PM
xelementx's Avatar
LOL!! at those things..... u can just take it off with your hands... rofl.... its the was the eaiest thing... nothing was really holding them down..
Old May 15, 2004 | 08:03 PM
Jonny98max's Avatar
hmm i tried pulling them off but they are stuck on there by something somehow....
Old May 15, 2004 | 08:24 PM
they have four clips, two on the top of the sides and two on the bottom of the sides
Kingofmaximas24
Nov 12, 2015 04:40 PM
Excalibur23
Oct 13, 2015 04:33 PM
16_SR
Sep 9, 2015 07:14 PM
Hdnseek
Sep 9, 2015 05:55 AM
