Removal pin stripping
Old May 10, 2004 | 06:54 PM
conz35's Avatar
How do i remove the factory pin stripping. Any tips on how to do this would be great thanks.
Old May 11, 2004 | 03:13 AM
David N.'s Avatar
Yeah, I am considering removing mine too. I think you just grab an edge and peel it off. If it is a tape pinstripe, that is. It might come off in many small pieces but it should peel off pretty easy once you get started.
Old May 11, 2004 | 04:59 AM
Shift_my vq's Avatar
IT's all about the hair dryer for this. Heat and peel
Old May 11, 2004 | 06:43 AM
belosic's Avatar
Use a hair dryer/heat gun and a small plastic scraper or old credit card to help with the small pieces. Glue will come off with rubbing alcohol. If it's painted on, go to a sign shop and have them remove it with xylene or "stripe remover" ( I have no idea what it's made out of, but sign shops and detailers seem to have it around and it works pretty well).
Old May 11, 2004 | 07:31 AM
phenryiv1's Avatar
Mod her. Ate her.
Park the car in direct sunlight and do that side, then turn the car, wait, and do the other side. Even if you are using a hair dryer, this will soften the adhesive in advance and make it much easier.
Old May 11, 2004 | 08:10 AM
scottcameron's Avatar
I did mine using a hairdryer and after a quick learning curve I was taking them off in whole pieces. The whole car took like 10 mins. I debadged my car at the same time using fishing line and hair dryer. I then used goop-off and finally a light rubbing compound/wax. Now you can't even see where anything was. It's a cinch...
my03maxima
Jul 28, 2024 07:40 AM
doctorpullit
Mar 29, 2016 11:08 AM
RealityCheck
Oct 2, 2015 06:34 PM
jaydot901
Sep 29, 2015 01:18 PM
Max Nu-BE
Sep 28, 2015 10:25 AM
