Wanted to do things myself, can i get some help on ECU codes
Old May 10, 2004 | 08:01 PM
sunnyyadav's Avatar
Hi, I am a new bee here, my check engine light came and when i checked the code by one of the process explained in one of the thread, i came to know that ECU error code is 32. By decoding the code it says: EGR System Hi/Low Flow. Can anyone help me, what needs to be done to rectify this problem.
Old May 10, 2004 | 08:51 PM
SupermaxGxe's Avatar
0302
Diagnostic Trouble code 0302 points to a problem with the Exhaust Gas Recirculation system. The malfunction is detected by the Engine Control Module when no EGR flow is detected under conditions which call for EGR. Possible causes include:
- The electrical harness or connectors (valve circuit open or shorted)
- The EGR valve is stuck closed
- Weak or dead battery
- The EGR passage is clogged
- Faulty EGR temperature sensor circuit
- A leak somewhere in the exhaust system
The EGR Volume Control Valve may be tested with an ohmmeter. Disconnect the electrical connector. Looking at the connector half which is attached to the EGRVCV with the latch at the 12 o'clock position you will see two rows of three terminals. The top row is numbered 1-3, right to left. The bottom row is numbered 4-6, right to left. Measure the resistance between these terminal pairs:
2 1
2 3
5 4
5 6
... all resistance values should be 20.9-23.1 ohms at 68 degrees F.
Reconnect the EGRVCV connector halves. Turn the ignition switch ON OFF repeatedly. Verify that the EGRVCV shaft moves smoothly forward backward according to the ignition switch position.
The Exhaust Gas Temperature Sensor may be tested with an ohmmeter. The specifications are ...
- at 32 degrees F, 0.68-1.11 Megohms
- at 122 degrees F, 0.09-0.12 Megohms
- at 212 degrees F, 0.017-0.024 Megohms
Old May 13, 2004 | 08:28 PM
sunnyyadav's Avatar
Thanks Buddy for this valuable information, I really appriciate.
Can you please let me know where is this EGR Volume Control Valve located?
Do anyone has pictures for this valve?
How to check if EGR passage is clogged or not?
Where is this EGR temp sensor circuit located to measure the Ohm's?
I think I would go step by step, If i get the location of the valve, first I will check the valve and if thats OK, I will check the temp sensor. What do u suggest, is this a good approach or something else is more better.
Thanks again...
Sunny
Originally Posted by SupermaxGxe
0302
2 1
2 3
5 4
5 6
CorollaULEV
30
Aug 9, 2021 08:11 PM
lux97Max
19
Aug 27, 2015 07:48 PM
Maxboy23
Aug 21, 2015 11:02 AM
kirkhilles
Aug 8, 2015 10:53 AM
MikesChevelle
Aug 6, 2015 11:36 AM
