trottle cable tension adjustment/gas pedal vibration/deep throaty sound during idle
Old May 11, 2004 | 10:36 AM
kenju4u's Avatar
Does anyone know if there is a write up to adjust the trottle cable that attaches to the gas pedal. I had read something about adjusting it so that it is tight and at the correct tension, which is usally done during a tune up. I see a little lag in mine. I am wondering if that is what is causing the vibration on my gas pedal during normal driving.
Also anyone know why i am hearing a deep throaty sound from my engine during idle which is mostly noticable during cold starts and when sitting inside the car with all windows closed.
Old May 11, 2004 | 03:10 PM
Terran's Avatar
Just adjust the nuts attached to the throttle cable (they're right near the TB). You need to loosen the one towards the back of the engine then turn the one to the front of the engine so that it pulls the cable. make sure the tensioner can still hit its stop. I hope you can understand that, it's kind of hard to explain. You may also want to clean the TB while you're at it as that can effect throttle response too.
Old May 12, 2004 | 05:04 AM
kenju4u's Avatar
thanks! i got it. I still dont understand the noise and the vibration on the gas pedal. Does this happen to anyone else?
Old May 12, 2004 | 11:19 AM
kenju4u's Avatar
any ideas guys???
Old May 12, 2004 | 12:32 PM
FormorAccordMan's Avatar
I too have a vibration in my gas pedal. And I don't know what it's coming from, everything looks good, but my friend did adjust the cable when I first got the car. hmmmmm. I am curious too
02PearlSE
Feb 1, 2016 12:37 AM
imported_Nismo_max
Sep 20, 2015 08:19 AM
lrb6805
Sep 17, 2015 04:49 PM
pktaske
Sep 4, 2015 08:40 AM
