300zx brake conversion?
Old May 11, 2004 | 01:06 PM
tynant's Avatar
what do I need to do this? I remember reading something about it in a post a couple weeks back but cant find it...(no search). Can someone give me a list of everything needed, where to get the items, and average cost? thanks!
Old May 11, 2004 | 01:57 PM
nupe500's Avatar
Jedi Knight
u need...
300z Calipers, rotors (milled 3mm off), pads for your calipers, stainless steel brake lines, Nismo studs depending on your wheels/rims or new rims with correct offset. Have to have at least 17" rims. Cost could range from $300-$1000 depending on what you need to get. Enjoy!
Old May 11, 2004 | 02:19 PM
tynant's Avatar
Originally Posted by nupe500
u need...
so this only works for the front huh? so I only need 2 300zx calipers, etc....also whats this about using a mustang cobra rotor? Is this better than using the 300zx rotor? do the 300zx just bolt right on after getting them milled? The difference is that the cobra rotors do NOT need to be milled? But they need an adapter plate whereas the 300zx rotors only need milling to fit? anymore I have masitaly presidents 18X8 but I have no idea what the offset is....got them used. can I get everything at advance? detailed info would be great! thanks!
Old May 11, 2004 | 04:13 PM
nismo_SHA's Avatar
this is actually not a bad price i know a couple of good webistes for oem parts too seeing as how big brake kits can run 3k 3hundy is very reasonable i just wouldnt like having different brakes on the back then on the front
Old May 12, 2004 | 05:15 AM
nupe500's Avatar
Jedi Knight
Details...there is really no difference/big deal in having them on the front and keeping the stocks in the rear. You braking improves so dramatically. Now with regards to the cobra rotors, I was planning on doing this upgrade from my 300z rotors, I have almost all the parts necessary. What that upgrade gives you is more surface area for braking thus disspating more heat (better) You will now also not have to get any rotors milled, you can get OEM and roll from there. I think that the hats on the rotors are different so that might change the needed offset on the rims...not sure..
Oh..and the 300z calipers DO bolt right on!
Old May 12, 2004 | 08:16 AM
jmeister's Avatar
Try here for a little more info.
http://www.mattblehm.com/brakes.html
Old May 12, 2004 | 08:59 AM
Jeff92se's Avatar
I'm needing a caw
Can't use the 13" Cobra rotor with his brackets
Old May 19, 2004 | 11:25 AM
tynant's Avatar
where can I find the stainless brake lines needed for the 300zx caliper and rotor upgrade? whats needed to do the upgrade oneself? Do I need a bearing press to remove the rotor? any help would be great!
Old May 20, 2004 | 04:40 AM
slizan99's Avatar
who sells just the relocation brackets?
Old May 20, 2004 | 04:59 AM
nupe500's Avatar
Jedi Knight
check in the general forum guys
aw11power
Oct 10, 2021 04:57 AM
Apr 16, 2020 05:15 AM
Calabar
Oct 5, 2015 09:57 PM
leatherneck
Sep 30, 2015 09:16 PM
HerpDerp1919
Sep 29, 2015 02:02 PM
