exhuast wrap?
Old May 15, 2004 | 06:18 PM
Jonny98max's Avatar
exhuast wrap?
ive been told exhaust wrapping the ypipe can eliminate some bees-in-the-can sound but will the wrap quiet down the whole exhuast system (ypipe +cat + catback)?
Old May 15, 2004 | 08:12 PM
Magikone69's Avatar
i need to know this aswell. i have the warpspeed Y and after i get up to 5k rpms it sounds a lil raspy. id like to quiet it down a bit
Old May 15, 2004 | 08:15 PM
happyricefob's Avatar
V^___^V
DEI exhaust wrap on the flex section.
close up of my DEI exhaust wrap. secured by hose clamps on both end.
Old May 15, 2004 | 08:16 PM
V^___^V
and mr. mortorvate wrapped his entire budget y-pipe with DEI exhaust wrap. check out his review and how-tos >> http://www.motorvate.ca/mvp.php/520
Old May 15, 2004 | 08:31 PM
Jime's Avatar
Read this too.
http://www.centuryperformance.com/heatwraps.asp
Old May 15, 2004 | 09:24 PM
bigleman's Avatar
Advocatus Diaboli
the thing is, that site warned against installing it on headers. is the y-pipe temp cooler than the headers? what if just the flex section was wraped, would that cause problems? are there any pipes that dont make noise? which pipes are direct bolton, i've heard you have to notch the warpspeed one to clear something.
Old May 16, 2004 | 02:38 AM
Jime's Avatar
I think its probably ok to wrap the flex but I wouldn't do the Y if it was mine.
Also remember that any warranty will be void if it fails while wrapped.
Old May 16, 2004 | 10:18 AM
image's Avatar
Dallas from warpspeed sent me a exhaust hanger for the y pipe. My y pipe rattles pretty bad, sounds like someones shaking up an ice maker. Do you think it will help? It rattles at the flex section and i put a new high flow cat on there so the oem heatshield is not needed. My question is, where in the hell do i put this? I took some time to take pics and research it. Any feedback would be great! (Sorry to ***** up the thread)
(I used Kevin's pic of his ypipe to give you an idea of where i think the exhaust hanger needs to be swapped out with the stock one)
Old May 16, 2004 | 12:07 PM
mansurxk's Avatar
looks like its supposed to go through the rubber hangers and on the ypipe right before the flange that meets the ypipe and the cat conv
i need to make one of those, how long are the hanger rods on that clamp?
Old May 16, 2004 | 12:08 PM
oTranscendental's Avatar
I heard that wraps lessen the life of your exhaust because the metal gets so hot it will eventually crumble, or get rusted a lot faster.
Old May 16, 2004 | 12:16 PM
Terran's Avatar
I would think that moisture and salt would also get trapped against the metal causing it to rust.
Old May 16, 2004 | 12:45 PM
image's Avatar
Man iono what the **** your talking about lol English, crayola pix.. anything!!! lol I dont no where the flange is or what it is. Im sure if i saw a pic i would no...
thye measurements are the hanger rods are 3 inch horizontal, 1 inch vertical...
If you got your pipe from wsp, call dallas and ask him to ship you one. He sent me this via fed ex for free.
Old May 16, 2004 | 01:00 PM
image's Avatar
the measurements are the hanger rods are 3 inch horizontal, 1 inch vertical...
Old May 16, 2004 | 04:06 PM
mansurxk's Avatar
he said $14 when i asked him when i first got the pipe, thats why id rather tell someoen to do it for me for free, you see the rubber hanger in the picture you posted, stick the rod into there, and put the clamp on the end of the ypipe where its going to the catalytic converter, im going to give dallas a call
http://www.skippynet.com/maxima/o2.htm
where the ypipe ends and goes to the cat convertor, look at that pic
Old May 16, 2004 | 05:41 PM
image's Avatar
Can i just crawl under there and do it or do i need a lift and some tools?
Old May 16, 2004 | 06:29 PM
Broaner's Avatar
2060lbs and falling...
I assume that you know you need a jack because you won't be getting very far if your the size of an average human. I would agree that wrapping reduces the exhausts durability in a northern climate. In a southern area this wouldn't be a problem and the performance gains could outweight the reduction in life of the pipe. I found that all my bees in a can noise was cause by the heat sheiding being slightly loose and vibrating. I removed all the heat sheilding in the exhaust corridor and the noise is now gone. I recomend doing this first and if the noise still exists go to the next step with wrap.
Mahmuth
Aug 16, 2024 08:23 PM
zzznightmarezz
Sep 21, 2015 06:32 PM
Krazzespiinz
Sep 13, 2015 07:10 AM
jerrod99_se-l
Sep 6, 2015 08:58 PM
TheMafia
Sep 4, 2015 08:26 AM
