Lug nut removal
I have one of those "X" shaped lug nut removers - makes it much easier to get the lug nuts off and on.. I don't know if its going to help you get any more torque - to break free tight lug nuts... try put a piece of pipe (2 foot or longer) or something similar over the the end of the standard tool so you get more leverage/torque... I've seen some people stand on the lug nut wrench and kinda bob up and down to exert force to break them free - that would probably work - but I'd be afraid of shearing the actual lug/stud from the hub...
You are trying to break them loose while the car is on the ground right? that usually helps to keep the wheels from spinning...
One more thing - soak them with a penetrant, e.g. PB Blaster and try after that...
First of all make sure the wheel is on the ground and not in the air spinning. Yes, many people do that and then come here asking questions. The standard tool should be enough as the lug nuts are only supposed to be torqued to 100ft/lbs. If you're weak then I can't help you.
HAHAHAHAH!!! i know it supposed to be on the ground and im not that waek but i don't wanna strip it or anything....I think that last shop tightened then way to much cause I have tried 2 different tires and can't even get one off.....how much is a power tool to get this done?
yeah just set it up and kick it. there is a point where you should just go to a shop and get them loosened with an air gun. if you kick it a few times hard it shock force should get them. the rule of thumb is if you thinks you'll break it leave it the ***** alone. they were put on with an air gun so they are tight. when you do get them off put some grease on the bolts so they don't stick.
I think a quicker/cheaper alternative (if your car is driveable) is to go to your local gas station/service center/tire shop/muffler shop and have them break the lugs loose for you...
FYI, a good compressor & impact wrench will run you maybe close to 400 bucks... or something around there...
Anti-seize... maybe.
The right answer: don't let the shop over-tighthen them.. or get home and loosen them and re-tighten them using a torque wrench... it will make your life easier next time and keep your rotors from warping... (too much torque/uneven torque on the lug nuts can lead to warped rotors).
Originally Posted by Nick7455
What is a good way to remove the lug nuts? I have just the standard tool and I am having trouble getting them off....any suggestions?
Seriously, I have had that happen to me (I bench-press 300+ lb.), so don't be embarassed. I took the wrench and put it on the lugnut just higher than parallel to the ground on the "9 o'clock to 10 o'clock" position and stood on the handle. I only weigh 155, but a few small bounces was all that it took to break it loose.
If that does not work, I think you may have to take it to a shop.
Originally Posted by phenryiv1
Wipe the sand out of your vagina and try again.
Really, Do your own stuff with your wheels. That way, you don't have to worry about them overtightening the lugs.
Do like everyone has said....just loosen while it is on the ground.
If you need to, stand on it like phren....
I bought this lil thing at walmart that plugs into ur cig lighter and it loosens it...works great....now since im done paintin my calipers on all 4 wheels i can go take it back and get my $$$$. Fukin dealership -_- (always gotta use lotta torque)
I'm surprised that anything that plugs into the lighter socket is and powerful enough (draw enough current from the lighter socket) to generate the torque to undo those lugs (if they were indeed as tight as you suggested)...
You can buy a thing mechanics call a breaker bar. It it basically a long handled rachet without the ratcheting action but rather with a swivel socket head that only moves side to side (hard to explain). The added leverage the long handle gives makes breaking any nut loose very easy.
Glad you got it off.
Originally Posted by Big D
I hope you wrote that with a sarcastic tone cause everyone here knows what a breaker bar is. Everyone calls it a breaker bar, not just mechanics. For something as rugged as lug nuts don't waste your money on a breaker bar. Like someone said before use a pipe or something.
Actually, no sarcasm intended. You'd be surprised at what some people do not know here. I don't assume anything, just try to be helpful in my own little way if I can. I've never not been able to break anything loose with my breaker.
Stupid a$$ mechanics have overtightened my lugs 3 times. Costed me 70$ total to get my wheel studs fixed after snapping them in half.
Yeah, get a Tire iron and breaker bar...itll help and speed up the process a lot.
And I think I would feel stupid plugging something into the cig lighter and using it on the lugs. I would not feel like a man if I could not even figure out how to break them loose with some elbow grease.
Originally Posted by Brudaddy
Next time that happens, ask me how to change them yourself. I think it is even easier than putting in new pads. Very simple...
Other than the balancing and alignment of your car, you ought to do that type of wheel stuff on your own. That is like the easiest stuff to do....wheel stuff. Changing pads, rotors, calipers, rotating wheels....that kind of stuff.
well im 17......I don't know that much about the brakes, rotors, caliper......wish someone would explain it more thoughly but i dont wanna go messing with it and break somethin
.....i do this technique too if the lug is overtightened
I started from nothing at one point as well. You just have to take your time and ask the right questions.
knight_yyz
Nov 1, 2015 01:34 PM
RealityCheck
Oct 2, 2015 06:34 PM
