Question about the trunk
I recently installed a sub in my trunk (single 12"). My problem is that it keeps sliding around back there, and the only holding in place is the wiring. I will check it every once in awhile and it keeps working is way toward the rear of the car, putting pressure on all the wiring. Is there any way of keeping it from moving? I thought about putting an extra board under the carpet toward the rear bumper to level out the slope of the floor more. Anyone else have the same problem? Any suggestions would be appreciated.
well, the way I did it was pretty ghetto. I had 2 12"s and they kept sliding around too, and that was a big box. I drilled an eye bolt into the front of the box and ran a black bungee cord from the bars accross the top of the trunk that work with the trunk opening and closing, through the eye bolt, and back up. I don't know if ya wanna do that, but it worked for me.
I know someone else with a large sub box in the trunk and they also used the L-bracket to bolt to the floor of the trunk.
True, it does make it a lot more difficult to get to the spare, but you can just unbolt it if an emergency.
Price you pay to have subs, I guess.
I have a custom floor (raised @ 2 inches) in my trunk so subs actually sit in floor and top of amp is flush with carpet. The L brackets is most common or u can screw in eyewhole screws to back of box and tie string/bungie box to back of seats
if you're worried about the spare, just carry around a can of fix-a-flat, unless you completely blow your tire out, then you're screwed. i still need to anchor down my subs, have 2 10s and a 12 in one big azz box and it keeps slidin around.
I use some very high strength velcro between the carpet and the box. The box hasn't moved since I put it on there, it's pretty easy to get off if you want to get to the spare, and the best part is that it takes all of 10 seconds to put the velcro on, none of that drilling stuff.
Thanks for the input guys.
I'm with "bosa1"..... but I made it even simpler.... added a "L" bracket to the top of the box and use 2 self drilling screws to attach the bracket to metal behind the rear seat.....the box does not move... and by pushing the subs up under the rear deck I have some trunk space left
Sounds like the best solution, at least for a start. Where did you get the velcro?
Unclejunebug
Apr 2, 2016 05:42 AM
Kyle Lee Cleveland
Sep 28, 2015 09:01 PM
