What indiglo gauges fit a 98 SE?
Old May 21, 2004 | 04:37 PM
Sqard's Avatar
I purchased a set off of ebay and realized they would not fit because I had the digital odometer. I then purchased another set made specifically for 98-99 and from the pictures they looked exactly the same. After trying to install them today the holes were slightly off and would not fit without drilling new ones. What gauges fit without having to drill new holes on a SE?
Old May 21, 2004 | 06:27 PM
bigleman's Avatar
Advocatus Diaboli
they sent you the ones for the 95-96, I had the same problem with the peg holes. I got mine from ProCarParts.com. I tried to send them back but the **** wouldn't take them back, he said that i was installing them wrong. would they still work if you drilled new holes? You'd still have to worry about the original holes looking sh!tty, right?
Old May 21, 2004 | 06:28 PM
Blackwind's Avatar
if you find some for a 98 se let me know.
Old May 21, 2004 | 07:28 PM
98MaximaSEguy's Avatar
This has been addressed a bunch of times...but i kno ikno....no search.
Dont drill a hole...just pop out the bump stop on the old gauges...and draw a mark where they would have to go for the new gauges to fit. then just cut a hole for the bump stop (in the old gauges) and slide on the indiglos (I believe theres a write up on vqpower.com) and you should be fine. Ive done it on mine, just take your time and dont rush it and you will be good.
Sorry I dont have a pic but Ill try to get one
Hope it helps.
Old May 21, 2004 | 09:30 PM
Ludacris's Avatar
Hope it helps.
Best noob evar. Yeah I ran into the same problem...none of the gauge faces will fit a 98-99 SE perfectly...you will either have to drill through the gauge face (which will work fine btw) or just cut the needle stoppers off and glue them on the new faces like this guy said.
Miket2006
Mar 1, 2021 03:55 AM
Apr 16, 2020 05:15 AM
trsandrew
Apr 8, 2016 06:45 PM
trsandrew
Oct 25, 2015 02:47 PM
Pied
Sep 26, 2015 03:29 PM
