Please help!
Old May 23, 2004 | 12:39 PM
ChargedSS's Avatar
Please help!
Anybody with some help with my problem. My 1997 Maxima keeps cutting out after about 20min of running. I already changed the fuel filter and pump, plugs and strainer for the fuel pump. Went for a test drive everthing was fine so I let the car run outside for 25mins and went for another test drive and car shut off again. What could this be.
Old May 23, 2004 | 12:53 PM
2naboy's Avatar
Run codes and see if anything comes up. It is likely a sensor and the culprit that come to mind id you MAF(mass air flow) sensor. It could also be your alternator not charging your battery well enough. If that be the case, go to autozone and have ytour electrical system checked.
