PCV valve
Old May 23, 2004 | 02:11 PM
dougmclennan's Avatar
PCV valve
Any tips on pulling out the PCV valve to check it? Is it alright to use pliers, or pry it out w/ a screwdriver, or will that crack it? I can't get a good grip on it w/ my bare hands...not much room to work there.
If I'm going to the trouble of inspecting it, should I just go ahead and replace it? Seems like a smart move since its such a cheap part.
Old May 23, 2004 | 02:47 PM
maximus_pr's Avatar
be careful with hose it breaks very easy like i did with mine
Old May 23, 2004 | 05:59 PM
JPMax's Avatar
What's next!?..
The PCV is connected to a short rubber hose which in turn connects to a small metal pipe that runs up over the intake manifold. Follow that pipe up and remove the screws holding it down. This will give you more room to work with. Pull the hose off the valve. Now grab the valve with some pliers and just wiggle it back and forth while pulling up at the same time.
Should pop right out.
Old May 23, 2004 | 06:20 PM
Pearl99GXE's Avatar
[QUOTE=
If I'm going to the trouble of inspecting it, should I just go ahead and replace it? Seems like a smart move since its such a cheap part.[/QUOTE]
Just go ahead and replace it.
Old May 23, 2004 | 06:52 PM
A32Matt's Avatar
definately watch the hose. mine fell apart like it was nothing.
Old May 23, 2004 | 07:14 PM
DAVE Sz's Avatar
Hooooooonda.....
It's a LOT easier to take it out than it is to put it back in.
Old May 23, 2004 | 07:54 PM
catalinoiu's Avatar
I agree Big D
It may be easier if you rub some engine oil on it. And Doug, just replace it man, it's like 4 bucs.
Old May 23, 2004 | 08:05 PM
LudeAEM's Avatar
yup! +2 on that one
TKHanson
Nov 24, 2018 01:39 AM
tseng1023
Oct 15, 2015 08:30 AM
hayne
Oct 5, 2015 11:53 AM
bumpypickle
Sep 20, 2015 08:22 AM
tardrex
Sep 11, 2015 07:35 PM
