safcII settings?
Old May 25, 2004 | 04:31 AM
cardana24's Avatar
Blown
safcII settings?
is anyone running a safcII on there N/A fourth gen? If so could you give me some ideas of what settings I can use. I am not trying to maximize my power right now but I would like my car to run safe until I can get to the dyno....thanks.
Carson
**I have CAI/Exhaust/and Y if this makes any difference
Old May 25, 2004 | 07:19 AM
cardana24's Avatar
Blown
is anyone using one N/A?
Old May 25, 2004 | 07:35 AM
96maxdaddy's Avatar
I take it safc stands for sequential air fuel controller?
Old May 25, 2004 | 07:38 AM
nismology's Avatar
S-AFC= Super Air-Flow Converter
Old May 25, 2004 | 08:11 AM
Jime's Avatar
Carson
If you are running N/A it will be safe, believe me.
I did manage to pick up a bit at the track N/A with the wideband and S-AFC but its minimal, but I do believe its worth knowing that the A/F is flat across the board.
Old May 25, 2004 | 08:18 AM
cardana24's Avatar
Blown
Do you have any suggestions to where I should have it set? I have it set for 6 cylinder, arrow up....hot wire 4 in 4 out...low throttle 35% high throttle 65% 01,01 on the MAF. I have played with another screen to set up something else with the throttle....but I was just hoping some one could recomend some safe base settings. Thanks.
Old May 25, 2004 | 08:36 AM
Jime's Avatar
Only difference I have is low throttle 39%, high throttle 40% and don't bother trying to program the low throttle because apparently the computer will just reset it back. So just the high throttle is programmed.
I wouldn't change any of the high throttle settings until you hook up to a wideband, otherwise you are just guessing.
tarun900
19
Dec 20, 2021 06:57 PM
aw11power
Oct 10, 2021 04:57 AM
knight_yyz
Nov 1, 2015 01:34 PM
Stagnet04
Oct 11, 2015 08:16 PM
JakeOfAllTrades
Sep 30, 2015 03:16 PM
