Is $243.60 a good price for a clutch shipped?
Old May 25, 2004 | 02:29 PM
95MAXIMASExy's Avatar
Is $243.60 a good price for a clutch shipped? it's from courtesy nissan it is the non key value one, it includes th cluth, pressure plate, throwout bearing, and the clutch alignment tool. all shipped to my house for $243.60. Where else is there a better deal if this isnt?
- thanks
Old May 25, 2004 | 02:35 PM
Terran's Avatar
unless your doing it yourself I would think you probably don't need the alignment tool right?
Old May 25, 2004 | 04:54 PM
i am doing it myself, (the tool is $8)
please let me know if i am getting ripped off on buying this clutch
Old May 25, 2004 | 05:09 PM
Chickan's Avatar
its not a horrible deal, but if you look around you can get others much cheaper, depending on what you are after. I picked up an Exedy (part # 06044) for $140 shipped, including pressure plate, friction disc, throwout bearing, and alignment tool. The pedal feels quite a bit lighter than the stock one, but it grabs great.
Old May 25, 2004 | 07:17 PM
pakteef's Avatar
Okay, explain this to me.....is the Exedy better than the OEM. Right now, my cluch is slipping in the higher gears and my clutch is sooooooooooo HARD. Like my left calf is twice as big as my right. Chickan, when you said "lighter than the stock one" did you mean the clutch pedal itself was light to press down? In addition, where can I get an Exedy clutch for a cheap price. When replacing the clutch, what else do i need to replace (i.e. presure plate.....)
THanks a lot for your input guys
Old May 26, 2004 | 05:39 AM
when replacing the clutch its standard to replace the pressure plate, and throughout bearing too.
Old May 26, 2004 | 06:38 AM
Brudaddy's Avatar
Do a lot of research man.
You don't want to end up with a clutch that does not fit your driving needs.
There are a lot of them out there.
tcb_02_max
Sep 11, 2015 12:23 PM
MAXSE5SPD
Aug 23, 2015 12:06 PM
maxinout93
Aug 16, 2015 07:25 PM
