Hard Shift
Old May 27, 2004 | 09:39 AM
buntypatel's Avatar
Hard Shift
When I drive my car everything seems fine but there is a big jerk from 1st to second gear. It's automatic transmission. I went to the mechanic and he said it was the engine mount ..but another mechanic told me to get the tranny replaced. The car works fine besides this one big jerk. Gears change smootley and car runs great. I'm not sure what the problem is....can someone help?
Old Dec 30, 2004 | 07:03 PM
mingus2112's Avatar
same problem
i'm having the EXACT SAME PROBLEM with my '99 maxima that i just purchased. no one has answered this yet? I really hope I don't need to replace the transmission!
-James
Old Dec 30, 2004 | 07:50 PM
kbmaxima's Avatar
i got the same thing. only thing i've been hearing is that its normal. if u revit up to 3k, youll get a smooth shift. i always do. but then youll waste a lotta gas. just live with it geez.
Old Dec 30, 2004 | 07:54 PM
yhtan76's Avatar
mine jerks a lil when revved all the way to ~6k rpm.
Old Dec 30, 2004 | 10:06 PM
Broaner's Avatar
2060lbs and falling...
Your cars are about to **** on your faces. Seriously though, your descriptions of this jerk aren't fantastic. Only on the 1-2 shift? Could be many things. I highly suspect it needs a tranny flush or it has faulty dropping resistor. I have an OEM dropping resistor for you. Have you ever flushed the tranny? Common sense should tell you that it isn't a mount cause it isn't behaving oddly on any other sh!ft.
Old Dec 30, 2004 | 10:12 PM
joew's Avatar
to reduce the jerk, you may want to look into synthetic oil.
Chino's Avatar
Are you sure the jerk is from 1st to 2nd? Or is it still in first and jerks at 2k rpm?
Old Dec 30, 2004 | 10:14 PM
2 Da Max's Avatar
the tranny is cold, put some ppl inside or let it warm up then it will go away. btw do a flush
Old Dec 30, 2004 | 10:24 PM
SHADETREE95's Avatar
Just do yourselves a favor and change the $40 dropping resistor.... Been there done that.
Old Dec 30, 2004 | 10:38 PM
mingus2112's Avatar
wow. . .so many responses. . .i'll try all of those!
just got the car yesterday actually. . .so tomorrow i'll observe a little more. . .i'm pretty sure it's only on the 1 to 2 shift though. . .
-James
Old Dec 30, 2004 | 10:40 PM
wayman's Avatar
I've got the same jerking problem from 1st to 2nd. I recently changed my tranny fluid and filter. While I didn't do a power flush, I did dump an extra quart of tranny fluid through the system while it was still open and let it drain out the pan to "wash" out any residual crap. The fluid coming out the other end was very clean.
Anyways, at least in my case, I don't think a tranny flush is the key. Like everyone else, I'm praying its not a faulty tranny. It shifts great everywhere else.
Can someone elaborate a bit more on this resistor? Thanks.
Old Dec 30, 2004 | 10:46 PM
2 Da Max's Avatar
dont worry about it, my car jerks so dam much ppl think my tranny is about to drop out.... wait then again i have the dr mod.
Old Dec 30, 2004 | 10:47 PM
The 1st to 2nd shift is the most pronounced that's all. Believe me I got the code for solenoid line control with all the same symptoms as you all. I think it was 1205 or something and before I knew about the dropping resistor I went ahead and put a solenoid pack in and still had the same problem. Then I changed the dropping resistor at a last ditch effort and that completely solved everything. Maximas with autos are notorious for that part going bad.
Old Dec 30, 2004 | 11:10 PM
wayman's Avatar
Where did you get the replacement dropping resistor? Any instructions on how to replace?
Old Dec 30, 2004 | 11:16 PM
Yup it's a dealer part $40. It is located on the driverside strut tower between the air box it's silver and has 2 10 mil bolts and 1 plug it's a 2 min job.
Old Dec 30, 2004 | 11:27 PM
wayman's Avatar
Sweet, thanks.
I figure since I know my tranny fluid and filter are fresh then it sounds like the dropping resistor is the problem. Even if it isn't, sounds like an easy thing to replace.
I'll let you all know if this does the trick. Will get to it after the New Year.
Old Dec 30, 2004 | 11:44 PM
You better call stealership I had to order mine.... It will take a couple of days.
Old Dec 31, 2004 | 12:52 AM
wayman's Avatar
Will do, thanks for the heads up.
Have fun at Ybor City on NYE!?!?
Old Dec 31, 2004 | 08:17 AM
Broaner's Avatar
Did you read my post? I have a dropping resistor for you. $20 shipped and its yours. It works perfectly. I just don't need it anymore. If it does turn out to be the tranny I have one of those also.
Old Dec 31, 2004 | 08:33 AM
mansurxk's Avatar
maybe if you werent so arrogant people would take the time to read your posts.
i have a jerk 1-2 shift for the past 2 years, once the car warms up its fine. obviously theres a problem, but its not detrimental to the cars performance or health.
Old Dec 31, 2004 | 09:00 AM
Broaner's Avatar
I was being arrogant? I was unaware offering my part to make it cheaper for him was arrogant.
There is no sense in buying a new one at full price when there is one available for half price. Several things are true when selling a good used part. Both people benefit. One gets the part cheaper. The other gets rid of a part that has been sitting in a box taking up space and gets a bit of money for it. Also, used parts save the environment because they don't use more of our valuable resources. And it makes it less likely that a good part will fill the landfill.
Old Dec 31, 2004 | 11:56 AM
A32Matt's Avatar
i'm having the same problem too. Once in a while the 1-2 shift will be pretty hard when i'm not on the gas very much. Annoys the heck out of me.
Old Dec 31, 2004 | 01:36 PM
joew's Avatar
replacement dropping resistor part number? want to order on-line.
Old Dec 31, 2004 | 10:11 PM
RockfordMax's Avatar
Back from the dead
werd. no more food in my car, after a big gulp and a long day of watching my gf clean it out of my carpet(haha i love being evil)
Old Jan 1, 2005 | 10:19 AM
mingus2112's Avatar
send me some information via pm. i can paypal you for that drop resistor so I don't have to order from the stealership. where are you located? i want to try this before my car's out of its 30 day or 1,000 mile warranty (i'm 3 days and 600 miles in right now!).
-James
Old Jan 1, 2005 | 12:00 PM
joew's Avatar
how long ago did you do this?
do you have the PN#?
Old Jan 4, 2005 | 03:31 PM
cam_honestiam's Avatar
Part # anyone?
Old Jan 4, 2005 | 03:44 PM
I tried to find my receipt with no luck. Just go to stealership and tell them you need a dropping resistor for an automatic trans. Either way it's about $40.
Old Jan 4, 2005 | 07:37 PM
Broaner's Avatar
Why? I have a perfect dropping resistor that you can have for half the price.
Old Jan 4, 2005 | 08:05 PM
Deagle's Avatar
wants the ads to die
Mine does this, and I'm sure it's the drop resistor. One other problem with my tranny is when it goes from 2-3 it seems to go in to 3rd and back to 2nd for a split second, it's barely noticeable, but it just seems like its searching for a gear to go into. Is it my driving or the tranny itself? I hope my tranny's going bad, it'd be a great excuse to do the 5spd swap.
Old Jan 5, 2005 | 12:56 PM
mingus2112's Avatar
brought the car to my regualr mechanic.
"you definately have a problem with your transmission."
that's what he said. he's not a "trans shop" so he couldn't tell me exactly what's wrong with it. he checked everything else out on the car and DID find a knock sensor code. (P0325) He also "doesn't do knock sensors because then another code always follows" whatever that means.
could the knock sensor have anything to do with this? i really don't want to have to bring this back to the TINY dealership and pay 50% of parts and 50% of labor if i don't have to. (that was the warranty. . .50/50 powertrain only. . .30 days or 1,000 miles. . .i'm up to 850 miles)
I just don't want to end up assuming it's one of these "fixes," and when i get around to replacing the parts, that's not the case and i'm over my thousand miles. . . .man. . .why does this have to be so tough??
-James
Unclejunebug
Apr 2, 2016 05:42 AM
hayne
Oct 5, 2015 11:53 AM
fx4five
Oct 1, 2015 04:58 AM
