Please Help !!!!!!!!!!!!
Old Mar 27, 2001 | 06:49 PM
max98boom
Hi Guys, i have a question for fellow maxima owners
i have a 98 max se
i replaced my fog lights with the H3 xenon 55watt blue tint bulbs.
they were fine
tonight pimping and realize my fogs are out, i checked the fuse by the battery but that one looked good it was a 15 fuse is that right?
BUt anyway what do you guys think happened im freaking.
Is there another fuse i should look for and what should i look for.
Please help
thanks
ROb
Old Mar 27, 2001 | 07:03 PM
Daniel B. Martin's Avatar
i have a 98 max se
they were fine
Please help
thanks
ROb
A gentle suggestion: make your posts with a more specific Subject. "Fog Lights Out" is more meaningful than "Please Help !!!!!!!!!!!!"
The fogs depend on power through two fuses:
- #53, 15 amps
- #63, 15 amps
If both fuses are good you could check
- fog lamp relay
- fog light switch
- fog light bulb sockets
- ground connection
- fog light bulbs
Old Mar 27, 2001 | 11:10 PM
Vitaly O.'s Avatar
if you touched the bulbs
they could have blown
Old Mar 28, 2001 | 02:59 AM
98blackmaxse
fog lights out
Is there 2 fuses for the fog lights 98 maxima,
i found the one near the battery, where is the other one
thanks
rob
Old Mar 28, 2001 | 04:05 AM
Re: fog lights out
thanks
rob
Fuse numbers 53 and 63 are both located in the long narrow fuse- and link-box adjacent to the battery.
Old Mar 28, 2001 | 04:16 AM
98blackmaxse
Re: Re: fog lights out
Thank you for that, ill check when i get home
hopefully that fixes it, do you think i should add a higher rated fuse if it is blown
Old Mar 28, 2001 | 04:30 AM
Don't upgrade the fuse
...do you think i should add a higher rated fuse if it is blown
Replacing a blown fuse with a higher rating fuse is the fast, easy, and wrong thing to do. The fuse is a protective device and when it blows it is giving you a warning. Changing to a higher rating fuse simply disables the protection. This may lead to a "toasted" wiring harness and a big repair bill.
If a fuse blows you should fix whatever defect caused it to blow.
