NEED major help...temperature needle touch te sky...
Old May 31, 2004 | 06:50 PM
Kbuitre's Avatar
ok guys i need your helop real bad... today i was driving down the interstate about 70 75 mph and I notice the temperature needle close to the line of almost burning... i stop check the coolant and everything was fine...i couldnt open the radiator cap... you know kind a hot at that moment... so i turn around and came back home I let it cool off for about 2 hours... I check after this cool off time the radiator level of coolant and it was to the top...so i tooked for a drive and i went up and down the interstate for about 45 minutes... and the needle never move from where it always stays right below the center of the circle...so what could it be the reason to kick the needle that much... anything would help... I really dont think the water pump is the problem... cuz it would trow it in the air in less that 5 minutes... so please help....
Old May 31, 2004 | 07:05 PM
d_warner's Avatar
Old Timer
Your thermostat might have stuck shut and not allowed any coolant by. After letting the car sit, the thermostat could have corrected itself. Given mileage and so on, you might consider replacing it. It's much cheaper to replace a thermostat as opposed to a head gasket.
Old May 31, 2004 | 07:43 PM
Kbuitre's Avatar
also what i should do i have a buzz everyonce in a while went i turn the radio... i think the ground is attached to something that shouldn't be...
Old May 31, 2004 | 07:46 PM
Wills98MaxSE's Avatar
1 of few unmodded 4G Maxs
same yr as Kbuitre, '98 SE w/ 105K on the odo, I don't have any overheat issues (yet), but I had a ? - would age and mileage be factors for replacing the thermostat?
Old Jun 1, 2004 | 08:54 AM
Kbuitre's Avatar
ok, I'm going to replace the thermostat but i got instructions for 3 different type of engines...
VG30E
VE30DE
VQ30DE
I think the "VQ30DE" is the engine i have...but the thermostat could be different on all 3 off them...if any body know something please email-me asap...I'm planning to buy it today...thanks
Old Jun 1, 2004 | 09:21 AM
njmodi's Avatar
Do I get a tax break?
Your maxima has the VQ30DE engine...
Old Jun 2, 2004 | 08:46 AM
Kbuitre's Avatar
Thats what i thought... i went to 3 locations to find the Thermostat but i finally got it...for 34.00 dollars...including the gasket and anti-freeze
aw11power
Oct 10, 2021 04:57 AM
captchaos
Mar 15, 2016 12:18 PM
HerpDerp1919
Sep 29, 2015 02:02 PM
Garrettz459
Sep 28, 2015 02:50 PM
Luigi623
Sep 21, 2015 01:42 PM
