AGX and Ground Control Question
Old Jun 7, 2004 | 12:11 PM
sean05's Avatar
do the agxs need modified to let the ground control coilovers to fit? If so how hard is it to do?
Old Jun 7, 2004 | 12:54 PM
Requin6's Avatar
i think some minor grinding of the lower strut perch is needed to accomodate the GC's. i dont think its a tough job, and nothing that a dremel or air grinder couldnt handle.
i am not sure of where you need to grind though as i have not installed GC's before. maybe someone else could be so kind to shed some more light on the subject.
--Paul
Old Jun 7, 2004 | 01:28 PM
sean05's Avatar
--Paul
Ya where can i get a dremel? I dont have either of those tools. i read on the Maxmod site that minor grinding is required bceause they might squeek. But i really dont want to grind them.
Old Jun 7, 2004 | 02:00 PM
Requin6's Avatar
home depot for the dremel. make sure you get or it comes with a metal grinding bit since you will obviously be grinding metal.
--Paul
Old Jun 7, 2004 | 02:17 PM
sean05's Avatar
--Paul
Alright thanks... I hope i dont have to grind them. I though they fit the AGXs but they had a problem squeeking and grinding was the solution.
Old Jun 7, 2004 | 03:03 PM
Iilac's Avatar
Spelled with a I not a L for Iilac. Prounced Ii-eee-ack.
You will have to dremel the front agx. It is not alot to dremel, the agx or the gc instrutions will have some diagrams on what to dremel.
Old Jun 7, 2004 | 04:46 PM
sean05's Avatar
grr... 10
sean05's Avatar
grr... 10 char
Old Jun 7, 2004 | 06:47 PM
DonSupreme's Avatar
Paul,
How do you think it was installed on my struts? Do you think it was grinded on my setup ?
Old Jun 7, 2004 | 08:09 PM
Oblongshapes's Avatar
Yes you will have to grind them, i used a bench grinder.... Also, it will not stay in alignment with the bearing plate using the Al top hats.... It may, but not on mine. I had to get rubber top hats
Any questions pm me
Old Jun 8, 2004 | 10:17 AM
sean05's Avatar
Originally Posted by DonSupreme
Paul,
Did you grind yours? Is there any way around this? Am i going to need a camber kit?
Old Jun 8, 2004 | 12:46 PM
DonSupreme's Avatar
I have a camber kit on mine. I am not sure what grinding is, but the coil over is directly attached to my strut. We took strut out, and even the ground control was directly attached to the strut. It may have been grinded, I didn't install it, so I am not sure.
Old Jun 8, 2004 | 08:31 PM
just camber bolts if you drop it the whole 3 inches.... 35 on SWA
Old Jun 9, 2004 | 06:38 PM
sean05's Avatar
how do i adjust or set the kit. where does it get installed? hehe i love suspension
Old Jun 9, 2004 | 08:24 PM
nick's Avatar
Re:
few pics for you....
Nick.
Old Jun 10, 2004 | 04:58 AM
sean05's Avatar
Nick.
thanks a bunch
Matt93SE
May 24, 2019 02:58 PM
Maxima_Joe
Nov 25, 2015 08:19 AM
95Maxi
35
Sep 2, 2015 10:37 AM
Maxima_Joe
Aug 27, 2015 12:01 AM
