Knock sensor
Old Jun 8, 2004 | 11:23 AM
mallen's Avatar
Knock sensor
I went to auto zone because (cel) was on they said the code was for a bad Knock sensor. So I looked in the haynes manual and got a ohm meter from work and checked it for continuity and that said it was fine which one should I believe. Also checked prices, they are high in my area is there somewhere you can buy them cheaper than 160-180.
thanks for any help
mallen
Old Jun 8, 2004 | 11:32 AM
felix's Avatar
Sittin' On Chrome
check ebay, i bought mine for $99.
Old Jun 8, 2004 | 11:33 AM
Terran's Avatar
Get it from ebay, courtesy nissan (not sure of site), or http://www.nissandealer.com/jerry-rome/part_catalog.cgi with "maxima" promo code. If you do replace it here's how: http://www.motorvate.ca/mvp.php/507, http://www.skippynet.com/maxima/knocksensor.htm.
Old Jun 8, 2004 | 02:21 PM
NmexMAX's Avatar
dot dot dot ...
www.pinnaclenissan.com parts section or www.thepartsbin.com
Old Jun 9, 2004 | 09:52 AM
MAXRB8's Avatar
$94 on e-bay $1 to ship look for ones sold by Yoshi, no problems, fast shipper brand new
Old Jun 9, 2004 | 10:36 AM
THT's Avatar
THT
Throbbing member
No, it's not just your KS. KS on it's own will NOT trip a CEL. Get your codes read again so you don't have to needlessly replace your KS if in fact, the ECU is throwing the code because something else is malfunctioning.
~THT
Old Jun 9, 2004 | 10:42 AM
FLO_BOY's Avatar
I would simply reset the computer and wait to see if it happens again...occasionally, there are fake codes thrown...I NEVER replace a part or try to diagnose until I get a code twice.
good luck!
FLO_BOY
Old Jun 9, 2004 | 12:05 PM
mallen's Avatar
went and had it checked again at different auto zone and came up with same code0325 which is a KS
Old Jun 9, 2004 | 12:11 PM
Terran's Avatar
Here's how to check yourself and reset http://vbxmaxima.8m.com/ecu.html.
Old Jun 9, 2004 | 12:32 PM
FLO_BOY's Avatar
was the computer reset?
if it was, then change the KS -- I hear that Yoshi is a good seller.
FLO_BOY
Old Jun 9, 2004 | 05:21 PM
mallen's Avatar
did as you said and got a code 0505 which said there was no problem
did 3 time with same result. should I wait for a while and check again a few days later since auto zone got one thing and I got another
Old Jun 9, 2004 | 05:24 PM
DonSupreme's Avatar
Mallen said "went and had it checked again at different auto zone and came up with same code0325 which is a KS"
I thought the knock sensor code was 0304?
Old Jun 9, 2004 | 05:34 PM
maximus_pr's Avatar
0325 code is what you get if you use the scanner wich is a bad knock sensor
http://forums.maxima.org/showthread.php?t=104931
my03maxima
Jul 28, 2024 07:40 AM
Kyle Lee Cleveland
Sep 28, 2015 09:01 PM
DC_Juggernaut
Sep 28, 2015 04:07 PM
