Rebuilding Calipers
Old Jun 9, 2004 | 11:27 AM
gabex's Avatar
Rebuilding Calipers
Well, I am changing out my front brakes.. Brembo Rotors and Axis pads.. and I was going to rebuild both my calipers because one was sticking. I was wondering if anyone had any write-ups or tips they could give me? Also, how do you remove the banjo bolt from the brake line to the caliper?
Old Jun 10, 2004 | 01:15 PM
gabex's Avatar
bump......
Old Jun 10, 2004 | 03:37 PM
Guttermouf5150's Avatar
i rebuilt my calipers, and it was fairly easy, except the i had a helluva time getting the boot around the piston and into the groove. i actually couldn't get it in all the way, but i was so fed up, that i just put it back together. i haven't had any problems yet! *knocks on wood*
i'm not really sure what you mean about the banjo bolt, because getting it off is a simple wrench job, 10mm i think.
Old Jun 10, 2004 | 06:33 PM
Prophecy1's Avatar
Also dont forget most companies will only charge you 75 dollars per caliper if you want a new one if you give them your old core. See with the new one you can throw down some nice paint on a clean caliper.
Proph
Old Jun 11, 2004 | 11:23 AM
gabex's Avatar
$30 for the kit to rebuild both sides. $5 for a can of brake cleaner, $5 for a can of Rust-to-Primer converter, $5 for some sand paper, $5 for hi-temp paint, $5 for clear coat.
Total: $55..
Old Jun 11, 2004 | 04:40 PM
G20Flyer's Avatar
$50 a piece remaned new at napa...im there.
Old Jun 11, 2004 | 05:15 PM
maximus_pr's Avatar
Total: $55..
plus the time you spend on each caliper and the risk that you may do it wrong
Old Jun 11, 2004 | 06:01 PM
Mishmosh's Avatar
$40each reman at Autozone. Not worth my time to rebuild. ...and yeah, I do fear that I may botch it up!
James92SE
142
Jan 2, 2024 09:23 AM
Miket2006
Mar 1, 2021 03:55 AM
Apr 16, 2020 05:15 AM
BkGreen97
Apr 2, 2016 05:47 AM
Pied
Sep 26, 2015 03:29 PM
