Stillen K&N Cone and Engine RPM
I have a 95 maxima with auto trans and it has 175K miles on it. I recently put on Stillen K&N Cone filter and the car started to drive funny. Below are the symptoms:
-- The engine RPM would drop all the way to zero and the engine would die. -- The engine RPM is very unstable, it would drop almost to 100 rpm and goes back up to over 1000 rpm. -- Because of the RPM fluctuation, the transmission would shift harsh sometimes. -- After installing the filter, I am getting a 0304 error code, which is to check the knock sensor I have tried resetting the ECU, disconnecting the positive and the negative terminals of the battery, but the problem has not gone away. Has anyone experienced this? Thanks! |
Knock sensor is going to serioulsly decrease power and acceleration ect. I would also double check all your vacuum lines.
+1 on the vaccume line thing, and make sure you have the MAF pluged in right, and anything else you dissconected.
Check your MAF connection. I had a similar problem, my MAF connector was not on all the way. Once I pushed it in all the way, I heard a click, & the problem was gone.
Thank you everyone. I'll try to recheck the MAF and vacuum connection. I'll report back. Thanks again!
I want to thank everyone on this thread. I reinstalled the MAF and the Stillen cone filter. After 2 days of driving, everything seems to be ok with the exception of one rpm drop when I was just going about 2 mph. I also clean the airflow and temp sensors with electronic cleaner just to be sure. Thank you!!
I am glad that it worked out for you.
© 2024 MH Sub I, LLC dba Internet Brands
