By pass KS?
Old Jun 18, 2004 | 06:20 AM
knight71's Avatar
By pass KS?
Who in here is running with a by passed KS via 470k resistor,,,just curious?
Old Jun 18, 2004 | 08:51 AM
Stephen Max's Avatar
Don't tell anyone, but I have been for about a week.
Old Jun 18, 2004 | 09:14 AM
aspec0002's Avatar
um how do u do this? which specific resistor is it? maybe check to see if this is whats wrong with my car
Old Jun 18, 2004 | 09:22 AM
Brudaddy's Avatar
Isn't that kind of dangerous?
I mean, the ks is there to prevent predetonation and if it happens(since you bypassed the ks), couldn't you potentially hurt or cause your engine to fail?
Old Jun 18, 2004 | 09:26 AM
I actually used two 1 Megohm resistors in parallel to give 500 kohms. You disconnect the wiring harness leading to the knock sensor and connect the resistor to the appropriate pin and ground the other end of the resistor. The harness will have two pins, you will have to determine which is the correct one. You can do it by trial and error. Connect to one and see if you get a 0304 code. If you do, that's the wrong pin. Be sure you clear your codes first.
Old Jun 18, 2004 | 09:31 AM
Not in an unboosted engine if you run 91-93 octane gas. Besides, any detonation severe enough to damage the engine will be quite audible, and even then it will take some time for enough damage sufficient to ruin an engine.
Presumably, people do this for short term testing purposes only.
Old Jun 18, 2004 | 09:37 AM
knight71's Avatar
Did u just tape on the resistor?
Old Jun 18, 2004 | 10:40 AM
Yes.
123456789
Old Jun 18, 2004 | 11:16 AM
belosic's Avatar
I tried this, after going through 3 KS's and still getting the code. I went to radio shack and got a 470k resistor, taped it in place, and everything was working great.... until I tried to go up a hill and got some knock. Even with 92 octane, the engine would knock. I guess my elevation is too high (7000').
Brudaddy's Avatar
Gotcha.
Thanks for clearing that up.
Continue about your merry way...ha ha
Old Jun 18, 2004 | 11:47 AM
95stillenmax's Avatar
a resistor is ok for the colder months but a actual good knock sensor is better during the hotter months
Old Jun 18, 2004 | 12:53 PM
maximus_pr's Avatar
anyone know the correct wich is the correct pin any pics?
Old Jun 18, 2004 | 01:44 PM
RichMax's Avatar
Boosted like Snipes tax refund
Works fine for me, but I wouldn't recommend it to anyone without a 99 California spec car. The rest of you guys should be able to replace the ks as soon as you have the $$... I'd need significantly more time/money to do so sinc i have extra cali. emissions hardware...
Old Jun 18, 2004 | 03:44 PM
maximomo's Avatar
I was thinking about doing this when my KS went bad. I replaced my knock sensor instead. Then read about these guys racing Altima's that mount the KS on the firewall. Does the same thing as bypassing it but you can always put it back on the block if you get ping ponging!
I mounted mine on the intake plenum and did a poor mans CAI on my filter box to bring the intake air temp down. NO KNOCKS and lots of power with 28mpg hwy doing 80mph all the way.
Of course, EVERYTHING else on my max is tuned to perfection so don't mess around with the knock sensor until you have everything else right.
Old Jun 18, 2004 | 06:29 PM
DAVE Sz's Avatar
Hooooooonda.....
Here's a little secret, engines knock almost all the time. Use 93 all you want but that stil doesn't STOP knock. There is VERY MILD knock almost all the time but it's not enough to damage anything. The audible knock stephen max described is the **** that you should be affraid of.
Old Jun 18, 2004 | 07:58 PM
maximus_pr's Avatar
so this is the resistor you used ?
1M ohm 1/4W 5% Carbon Film Resistor pk/5
$0.99 Brand: RadioShack
Catalog #: 271-1356 Model: 271-1356
Old Jun 18, 2004 | 08:04 PM
A32Matt's Avatar
been runnin the resistor for over 2 months with 93 octane all the time. no knock. it runs pretty good, but i wonder how much better it would run with the KS.
Old Jun 19, 2004 | 05:04 AM
CUSEMAX's Avatar
im using the same thing becuase my car is 99 cali as well.... i am using two resistors in series, which gave me a total of 530kohm's this is working really well... good luck, always use 93 octane!!
Old Jun 19, 2004 | 08:55 AM
maximus_pr's Avatar
any pics thinking on working on that this weekend but i want to to a nice temporary job until i can buy the ks(out of cash buying the bumper and related parts after accident)
Old Jun 19, 2004 | 12:04 PM
ABK's Avatar
ABK
Yeah I just found out my KS went no wonder my gas milage sucks, I don't know what's better running with resistor, or running rich and making my O2s prolly burning out faster. BTW I always run on 93 octane.
Oh yeah do J30t use KS, and is it comparable to a maxima one? Or 3rd gens?
What other cars have comparable KS, I think 93-99 altimas and 95-99 sentras, but anything else that has one that will work with maxima.
Old Jun 19, 2004 | 12:35 PM
maximus_pr's Avatar
i went to radio shack i bough 5 1Mohm resistors but i can't remeber how is parallel so anyone can tell me
also be working on drop resistor but with on/off switch no wot switch
Old Jun 19, 2004 | 08:10 PM
maximus_pr's Avatar
you say that you used 2 1MOhm resitors in parallel wich gives you 500Kohm but does it works like that?
edit- i found this links it shows it really but not the same as speakers http://www.electronics2000.co.uk/calc/calcrsp.htm
Old Jun 20, 2004 | 08:11 AM
knight71's Avatar
Okay..Let me get this straight..we disconnect the wiring harness thats attached to knock sensor end? or the other end?.and also,,did you connect each 1m resistor to each other?, or both resistors on one pin?
Old Jun 20, 2004 | 01:24 PM
CUSEMAX's Avatar
in my opinion its much easier to connect things in series than in parallel... esp when you dont want to worry about soldering things. I went and bought the big pack of resistors from radio shack, and then asked one of the geeks there to pick out a 220 and 330 k ohm resistor from the package. i then connected them together in series and had him test that it was indeed 550 kohm's with his multitester. i then just went out, inserted it into the car, and wrapped more electrical tape to hold it in place... all in all, it was a very pleasant experience, to bad i didnt have a beautiful blonde helping me instead of the geek...
Old Jun 20, 2004 | 02:11 PM
DAVE Sz's Avatar
Hooooooonda.....
You shouldn't run the resistor for more than a couple weeks. Not having any kind of protection against knock, especially in the summer, is stupid. Get some $$ together and buy a KS cause in the long run getting a new engine will cost more.
Old Jun 20, 2004 | 04:20 PM
greenmax95se's Avatar
i was reading on is300 forums and they have a KS bypass type device. for guys with exhuast/cats that throw codes. i'm pretty sure they will not work for us, because they made for those cars only.
-rafal
Mar 12, 2020 12:06 AM
09maxshawn11
Sep 30, 2015 10:28 AM
hntwhttail
Sep 12, 2015 03:43 PM
