Test pipe = CEL?
Old Jun 18, 2004 | 05:01 PM
2maximas's Avatar
Test pipe = CEL?
Does the CEL lamp I get after I put on my test pipe (nice one with glass packing and chrome plated) really a situation I need to address? according to the diag decode I have 3 cylinders running lean, (or a couple of other things, one of which is addressed later in the post) I can reset it and it may go 100 miles or 20 before it comes back on. If it's lean, that REALLY bothers me....BUT
I just wondered if this was a real prob. or not, the code also says it may be an exhaust leak too and I think that is more than likely what it is, as i do not think I got the dam thing sealed good enough. BUT the good thing is I can change it EASY now after breaking the nuts and bolts loose! and reassembled with anti seize! Mine sounds almost no different than stock, I can still hear the intake howl way louder than the exhaust and it's nice and quite thru all RPM ranges, been on 2 long trips, no droaning at all.....
Any help appreciated allot.
2Maximas
Old Jun 18, 2004 | 09:01 PM
Tyrexx's Avatar
Many have NOT caused a CEL.
Old Jun 19, 2004 | 07:28 AM
RA030726's Avatar
I'm nutty for Nissans
the only way to find out is to put the real cat back in. BTW test pipes are junk.....waste of money and time, bad for the environment including you and me, and they are illigal. The stock cat out flows the engine too.
Old Jun 19, 2004 | 08:09 AM
meccanoble's Avatar
Sports Button FTW
only if your n/a and even then it does show very minimal gains i believe. a test pipe isnt hooked up to anything on a 97 max.. It shouldnt show a cel light.
Old Jun 19, 2004 | 09:52 AM
96maxdaddy's Avatar
HA I love this. why do you think there is an o2 sensor in or behind the cat? Do you think Nissan just threw in an extra one? NOOOOOOOO, I have said it befor and I will say it again. Test pipes are CRAP, unless you like a CEL. That rear o2 sensor is for monitoring the Cats efficiency. If there is not cat there, the computer wont like what its seeing the o2 sensor read and throw a trouble code. WELCOME TO OBD2.
Old Jun 19, 2004 | 11:23 AM
RA030726's Avatar
thank you 96maxdaddy for explaining the rear O2 sensor.... some people will never learn.
Old Jun 19, 2004 | 11:35 AM
DAVE Sz's Avatar
Hooooooonda.....
I think you got it wrong. It should be test pipe = POS.
Old Jun 19, 2004 | 12:48 PM
2maximas's Avatar
And tell me.......why is that? Why are they sold, who decided that.....you? They seem very popular, allot of them are sold, so whats up with that?
Old Jun 19, 2004 | 01:10 PM
2maximas's Avatar
REALLY????? you mean that the O2 sensor dosent like whats coming out of the now non existant cat? WELL DAM ME can you imagine that??????
I know full good and well WHY it dosen't like it, I want to know how to make the CEL not come on, not an explanation of WHY it's coming on. I know that if I knew the values I could cheat it, that is the kind of info I'm looking for, something you must not know anything about. or don't care about, if you are worried about emissions buy one of your honda hybrids! AND I'm Quite sure you are not running a aftermarket Y pipe, cause they remove the 2 pre cats too.
Old Jun 19, 2004 | 03:59 PM
DAVE Sz's Avatar
Hooooooonda.....
They polute much more than a car with a cat converter and they gain no power, it's a dyno proven fact. It's a waste of money. How do you know alot of them are sold? Unless you buy all of them you don't. Not alot of them are sold cause people know they are crap.
Old Jun 19, 2004 | 04:09 PM
2maximas's Avatar
You got a dyno sheet to show me?
I think treehuggers=POS
Old Jun 19, 2004 | 04:11 PM
95stillenmax's Avatar
I think your O2 sensor might be bad or might have been damaged when you transfered it because they are fragile
Old Jun 19, 2004 | 04:45 PM
Stillnmax's Avatar
umm well i dont have an O2 Sensor behind my cat... long live cali-spec ...
Old Jun 19, 2004 | 05:30 PM
DAVE Sz's Avatar
Hooooooonda.....
I don't but that's because I don't care for it. There is one so look for it yourself. I'm not a treehugger you *****, I just like breating fresh air. Don't be mad cause you wasted money on something useless.
Old Jun 19, 2004 | 10:40 PM
RA030726's Avatar
yeup test pipe=crack pipe.
Old Jun 19, 2004 | 10:45 PM
96maxdaddy's Avatar
Posted by 2maximas - Yesterday at 03:10 PMI know that if I knew the values I could cheat it, that is the kind of info I'm looking for, something you must not know anything about. or don't care about
Your right I DONT CARE.
Posted by 2maximas - Yesterday at 03:10 PMif you are worried about emissions buy one of your honda hybrids!
Who said I was worried about emissions? I could care less.
[QUOTE]Posted by 2maximas - Yesterday at 03:10 PMAND I'm Quite sure you are not running a aftermarket Y pipe
Yes I am.
Posted by 2maximas - Yesterday at 03:10 PMcause they remove the 2 pre cats too.
So what!! Thw two precats are AFTER the front two o2 sensors!!!
Old Jun 20, 2004 | 08:57 AM
2maximas's Avatar
Geee, you see to be knowledgeable about crack pipes, got a few? Personally I wouldn't know a crack pipe from a drain pipe but you seem very knowledgeable, if I ever need a CRACKHEADS advice, I'll definately look you up!
Old Jun 20, 2004 | 09:34 AM
2maximas's Avatar
Thanks, you have been very helpful, I'll make sure that anyone that needs help looks for you, you are such a nice guy and so knowledgeable.
[QUOTE=96maxdaddy]Your right I DONT CARE.
Yes I am.
jmlee44
Oct 2, 2022 02:13 PM
tarun900
19
Dec 20, 2021 06:57 PM
aw11power
Oct 10, 2021 04:57 AM
Quickywd01
Sep 21, 2016 09:36 PM
